Sponsored by: Real Truck
rescue 1
Old Sep 22, 2008 | 01:46 PM
rescue 3's Avatar
rescue 3
rescue 1
1999 f350 7.3 srw 4x4 my speedometer stopped working where is the sensor. ive replaced the vss on the rear axle, no change. speedo shoots to 40 mph and stays there
Old Sep 22, 2008 | 02:07 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Moved to Superduty Forum, I am sure you can find some help here!
Welcome to FTE - good luck with your problem!
Old Sep 22, 2008 | 02:33 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Are you sure you seated it fully? and the connections were good & clean? I'm not sure where any other sensor might be, but I'd try getting the rear wheels off the ground, hook a DVM up to the VSS sensor, and then put it in gear and rev it up a little. See if you're getting some variable voltage or current. Check for a pinched/nicked/broken wire too.
This is a new one, lucky you...
Old Sep 22, 2008 | 03:34 PM
riggz's Avatar
riggz
Just a bit of helpful info, when you start a thread pick something that closely describes your question or information for the topic instead of your user name.
Old Sep 23, 2008 | 09:02 AM
krewat's Avatar
krewat
Is the ABS light on, or is the OD light on the shifter blinking?
