Unless you've got substandard fuel quality over there, I can't see carbon buildup being an issue on an '08 model with 36K miles.
JL
I've tried various big name fuel retailers. Right now I have the best luck with Valero.
Originally Posted by dkf
What rpm range does the ping occur and at what throttle position?
It will knock, almost like a stick in spokes at WOT (once it's over 4500 RPM)...some times.
Then it will knock to a lesser degree when under load at lower (2200-2500) RPMs....sometimes.
Usually a jab at the throttle will cause the truck to downshift and the knock will go away.
That's odd. Valero fuel knocks in everything I own-not so bad in the truck,but the Navigator and Tbird both knock terribly with Valero fuel in the tank.
JL
Under load is when I found the knock to be the worst. If you relay this info to Mike he can adjust your tune some in the rpm ranges the knock occurs. A custom tune with a tiny bit of timing taken out is still a hell of a lot better than the stock tune.
I get a slight ping in my 04' when the engine is loaded good under 1500rpm. Its a lot easier to hear with the headers on than the stock manifolds. I pretty much exclusively run Sunoco fuel and when on a trip try to also but I really don't notice much of a difference in fuel here. Canada fuel however smells different but still runs good.
JL
Yeah, it's starnge. I used to avoid Diamond Shamrock because it seemed to have less than the rated octane. But lately, as Valero, it seems better.
Chevron used to be my brand of choice, but spark knock is the worst with that fuel right now.
Shell is pretty good. Exxon, not so good. We recently got a Texaco in town, might have to try them again. That used to be my brand of choice.
I don't think it makes much of a diffence anymore though. Most of the fuel is delivered to all stations in this areais by MidTex or Coastal, with additives added at the wholesale rack or upon delivery to the in ground tanks.
I mostly try to use a newer station or one that does a lot of business to avoid stale or contaminated fuel.
I have a 2000 F250 SD 4x4 automatic and have had the pinging/knocking under acceleration ever since I bought the truck. Recently I had a check engine light with a code P0174 - Lean left bank. I would clear the code and after running the engine for a few minutes the code would come back. One day I heard a hissing/whistling noise from the engine and discovered that the Positive Crankcase Ventilation (PCV) hose, that connects to the intake manifold underneath the throttle body, was cracked. I taped the crack closed, cleared the code and the code didn't come back. My tape-up job didn't last very long so I replaced the hose with a fuel rated 3/4 rubber hose and hose clamped the other end that connects to the hose for the PCV. The other day when I accelerated up a few mountain roads, I didn't hear the pinging/knocking. I'm thinking that the PCV hose line to the intake manifold was sucking in additional air that would cause the fuel system to run lean. Anway... it seems to be working for me. In all my discussions with Ford tech, they never brought up this possibility.
Unmetered air entering the engine will cause knock sensitivity or spark knock if the leak is big enough,but in the case of the V10 Superduty-the OEM tune is terrible,and is the cause of this knocking issue.
JL
