replaced clock spring - still have 32 code
Old Sep 22, 2008 | 09:48 AM
groho's Avatar
groho
Got a 32 code on my dash for the airbag. Replaced the clock spring, but still see a 32 code. See the lead running to the ign switch. It looks like the self-check process starts as the ign switch is turned on. Assuming I have a good clock spring cuz it's new, is it possible the ign switch is bad? It looks as if the switch is part of the circuit during the self-test process. How often are the clock springs bad outa the box?
groho's Avatar
groho
BTW, replacing the clock spring was a piece of cake thanks to this forum. Did it in about 45 min. thanks for the help.
