Help!I need some advice,,I won't to replace the oil seals in the front and rear of my 360cid, what else should I do while I'm in there. It's in a 75 F-250 H-Boy. thanks in advance Tin-man
Look up PAW.com they offer complete engine kits for the 360 for around
Deluxe engine rebuild kit 194.00
-piston rings
-rod bearings
-main bearings
-oil pump
-complete engine gasket set
-timing chain set
thats what i would do, it waould also make it easier to inspect the rest of the engine for excesive wear on parts that might fail after you do the seals
