General Diesel Discussion
Does Cylinder Pressure = HP?
Old Sep 21, 2008 | 03:34 PM
mcpga's Avatar
mcpga
Please help me settle an argument!
Do all performance adding tuners, chip and programmers add cylinder pressure or can HP be added without increasing cylinder pressure? If so, how?
Old Sep 21, 2008 | 06:51 PM
884x4broncoII's Avatar
884x4broncoII
they add fuel and change injection timing to create a more powerful kaboom
Old Sep 24, 2008 | 09:04 AM
Pocket's Avatar
Pocket
Cylinder pressures do increase with added fuel and changes in timing, which is what most chips and tuners do. It's physics. However, CP's can be controlled with good tuning. You can take a stock injectored truck, throw too much timing into it, and raise the CP's enough to break a rod. Then again, you can swap in some 230cc injectors, nail the timing just right, adjust the fuel pulsewidth, and keep the CP's in check so you don't destroy the engine. In the end, the extra fuel from the larger injectors will give you more HP than a stock injectored truck. So higher CP's don't always equal more power.
Old Sep 24, 2008 | 04:40 PM
mcpga's Avatar
mcpga
Thanks! That answers my quesion!
