feul pump keeps running(help please)
Old Sep 21, 2008 | 02:50 PM
towrig350's Avatar
towrig350
89 f250,302,with the key in the on pos. the fuel pump runs then stops then runs, and keeps doing this & doesn't start, no spark.
Old Sep 21, 2008 | 04:34 PM
subford's Avatar
subford
Does it crank?
Sounds like the Power Relay is making and then dropping out.
Ignition switch maybe.
Old Sep 21, 2008 | 04:45 PM
towrig350's Avatar
towrig350
yes it does crank
Old Sep 21, 2008 | 04:57 PM
subford's Avatar
subford
Originally Posted by towrig350
yes it does crank
Make sure the computer ground wire (black with a green stripe) has a good ground at the ground post of the battery.
If good make sure the wiring under the power and fuel pump relays is good, this seems to be a problem with your year.
If OK check to see if the power relay is making clicking sounds with the key on.
If so you may have a bad Ignition switch or its plug my be burnt down by the floor board on the column.
Old Sep 21, 2008 | 05:29 PM
towrig350's Avatar
towrig350
is the power relay under the hood on driveside? because their is a clicking sound with the key on. also from the dizzy.
Old Sep 21, 2008 | 05:33 PM
subford's Avatar
subford
Yes the power relay is under the hood on driver side.
I do not think I have ever heard of a distributor making a clicking sound with the engine not running.
Old Sep 21, 2008 | 07:13 PM
towrig350's Avatar
towrig350
when it clicks is when the feul pump comes on. **** is crazy can't fig out
Old Sep 21, 2008 | 07:28 PM
subford's Avatar
subford
Maybe this will help.
Old Sep 22, 2008 | 06:10 PM
towrig350's Avatar
towrig350
put a new Ignition switch on,still nothing,now fuel pump comes on one time only(like it should),tac doesn't move when cranking,shouldn't this jump?
Old Sep 22, 2008 | 06:22 PM
subford's Avatar
subford
Check for power at the ignition coil with a test light, the tach side should flash while cranking and the other side should have power on it at all times the key switch is on.
Also check to see if you have power at an injector, any injector, both sides should have power with engine not running.
Old Sep 22, 2008 | 07:47 PM
towrig350's Avatar
towrig350
tach side goes dim when cranking
Old Sep 22, 2008 | 07:53 PM
subford's Avatar
subford
Is it cranking very slow?
Old Sep 22, 2008 | 08:09 PM
towrig350's Avatar
towrig350
cranks over fine
Old Sep 22, 2008 | 08:27 PM
subford's Avatar
subford
It should flash, maybe a bad TFI module.
Old Sep 22, 2008 | 08:41 PM
towrig350's Avatar
towrig350
thats new too.had them test it said it's good
