feul pump keeps running(help please)
Old Sep 22, 2008 | 08:50 PM
subford's Avatar
subford
Check the plug at the coil and make sure it is OK.
The PIP sensor with the TFI module should take this Tach wire to ground off and on while cranking.
Make sure the distributor is grounded also.
The ground for this system is inside the distributor, check the ground pin at the plug on the TFI module with the harness unplugged and see if it is at ground (zero ohms).
Old Sep 23, 2008 | 12:15 AM
deeznuts822's Avatar
deeznuts822
id recheck the wiring under the relays, mine had one corroded and gave me hell
Old Sep 24, 2008 | 04:54 PM
towrig350's Avatar
towrig350
what color is the ground, black and orange tracer? on dis. plug
Old Sep 24, 2008 | 05:04 PM
subford's Avatar
subford
It is not a wire it is the bottom pin.
Check it to ground while it is still on the distributor.
Old Sep 24, 2008 | 05:26 PM
towrig350's Avatar
towrig350
ok..it's got ground
Old Sep 24, 2008 | 05:47 PM
subford's Avatar
subford
I take it you have no spark right?
I say this because you said the light bulb just dimmed and did not flash.
Old Sep 24, 2008 | 08:08 PM
towrig350's Avatar
towrig350
yes ,no spark... sumthing is up with the harness the fuel pump keeps running and stopping,their has to be a short
Old Sep 24, 2008 | 08:09 PM
towrig350's Avatar
towrig350
also thanks for all the help (subford)
Old Sep 25, 2008 | 04:22 AM
subford's Avatar
subford
Remove the SPOUT jumper at the bottom of the distributor.
See if you have spark now.
If no spark (and no flash at coil) and the TFI is good and the engine wiring harness is good from the distributor to the TFI then it sounds like a bad PIP sensor in the distributor.
If it is a bad PIP sensor you will need to replace the distributor.
If you need help replacing the distributor post back and we will help you.
We will look at the Fuel Pumps after we get spark.
Old Oct 7, 2008 | 04:28 PM
towrig350's Avatar
towrig350
just put new pip in,still no spark.
Old Oct 7, 2008 | 04:41 PM
subford's Avatar
subford
If you have a new PIP, TFI module, the SPOUT is unplugged and you have power on the + (POS) side of the coil with the key on. I think you said you changed the coil also, so the only thing left for no spark would be the wiring from the distributor to the coil and the spark plug wires.
Old Oct 7, 2008 | 05:19 PM
towrig350's Avatar
towrig350
with the key on,and the dizzy lose and i turn it, the fuel pump relay starts clickin and running,and now it pops when turnin over.
Old Oct 7, 2008 | 05:36 PM
  #28
subford's Avatar
subford
The fuel pump is coming on because the computer saw a pip pulse.
If the engine "pops" then you have spark.
Sounds like you are out of time.
Check spark and valve timing.
Old Oct 8, 2008 | 08:54 PM
  #29
cpettymore7777's Avatar
cpettymore7777
is your tach aftermarket? if it is it should bounce a little when cranking it. that should mean that the coil is getting voltage to it
Old Oct 18, 2008 | 06:34 PM
  #30
towrig350's Avatar
towrig350
ok,i have spark now,but still will not start.
DIRTYSTEVEN
Aug 18, 2012 10:37 PM
dieselboy3278
Sep 15, 2009 08:25 PM
pensacolaF150
16
Apr 7, 2004 09:55 PM
Greg Schretter
Oct 12, 2000 07:42 AM
