How do you......
Old Sep 21, 2008 | 08:02 PM
Kwikkordead's Avatar
Kwikkordead
Yes the parking brake is dedicated on the Superduty.
Old Sep 21, 2008 | 08:15 PM
redfire42's Avatar
redfire42
I did not know that!! Thanks guys. Can you still dragg your ebrake?
Old Sep 21, 2008 | 08:19 PM
ron's power stroke's Avatar
ron's power stroke
yes you can...
Old Sep 21, 2008 | 08:23 PM
redfire42's Avatar
redfire42
I think I did it once, coming home from a camping trip. Boy and my ebrake sux also.....
Old Sep 21, 2008 | 08:30 PM
ron's power stroke
if you cook the brake shoes from draging them..they will not hold as good again...the good thing is..when you do cook them..you still have good foot brakes to stop you....
Old Sep 22, 2008 | 05:26 PM
stroke-of-luck00's Avatar
stroke-of-luck00
FYI...i popped off that little cover and tightened that star nut. worked like a charm!!! this site is MONEY!!!!!!!
Old Sep 22, 2008 | 11:08 PM
PaysonPSD's Avatar
PaysonPSD
With help from FTE you can sometimes have your cake and eat it to.
It really is quite easy once you start turning it in the right direction. I bet the e-brake pedal doesn't go all the way to the floor anymore.
Old Sep 23, 2008 | 09:09 AM
03_PSD's Avatar
03_PSD
i need to do this, my ebrake isn't holding inclines any more.
Old Sep 23, 2008 | 09:52 AM
F250_'s Avatar
F250_
This may be obvious, but I'll mention it anyway because I know that sometimes I overlook the obvious myself.
When you adjust your ebrake, guys, pay attention and listen for any signs of dragging after making the adjustment. It would be a shame to over-adjust and either damage the drum surface inside the rotor assembley or burn up what little there is on those small E-brake shoes, and those little shoes are NOT cheap, either!
Old Sep 24, 2008 | 12:41 AM
kbeefy's Avatar
kbeefy
Yeah,
Originally Posted by kbeefy
they should be looked at at least every 50k.
Old Sep 24, 2008 | 08:07 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
If you adjust your brakes and find out they really need replacement, getting that drum/rotor assembly off can be challenging. The lip on the inside of the drum hangs on the pad, dont ask how I know this.
Old Sep 24, 2008 | 08:36 AM
Kwikkordead
A lot of times what happens is the cable gets bound up. Then it will not transfer the load from the parking brake pedal to the drums, but rather about half of the force will be absorbed by the sticky cable. To the driver it feels like you are stepping on the pedal with sufficient force, but what finally arrives at the parking brake assembly is quite a bit less.
The other factor is on whether the assembly inside the drum is getting siezed up from rust.
In that case the only solution to get a good parking brake back is to remove the drums, clean, lube the lever pins, etc.
This sort of thing happens all the time with parking brakes on all vehicles.
I replace parking brake cables a LOT, even in a non rust belt area like Seattle, WA.
You people on the east coast, I would be surprised if your cables can still move freely.
