Offroad & 4x4
cowl induction hood project
Old Apr 25, 2002 | 06:57 PM
Chuck P.'s Avatar
Chuck P.
Toying with the idea of using closable vents like the ones for a forced air heating system in a house, thinking 6" x 12" or so. Would place one on each side of the hood, close as possible to the cowl, with-hopefully-a cable operated system to open/close. Would also use removable clear plastic covers for the "cowl" or reverse scoop (bolt-on type, suppose to be shatterproof), in this way they could be removed for off-road trecks and used as a deflector for the windshield area in front of the driver and passenger. I think this would allow the hot air to escape during wheelin' and on warmer days, yet still be closed during wet or cold weather-don't want any water on my engine! Think this is so far "off-the-wall" as to not attempt it? Any thoughts or comments before I hack my hood will be greatly appreciated!! Thanks, Chuck
Old Apr 25, 2002 | 07:28 PM
Yeti's Avatar
Yeti
[updated:LAST EDITED ON 25-Apr-02 AT 08:29 PM (EST)]Well Chuck, from looking at your gallery at your "track bar" it seems you like to try things.
On our Nascar Modifieds that we build, we call it a tourqe arm, but we also use coil overs and bird cages to mount them.....any how, why not pick another hood up to try this experiment on? that way you still got your good hood incase things don't go so well?
Just a thought
Old Apr 26, 2002 | 11:05 AM
KJKozak2's Avatar
KJKozak2
Chuck,
Here's another thought. On my horse trailer, I have flip open vents above each of the horses heads. You can open them frontwards or backwards to either scoop air in or suck air out. They have a rubber gasket around the opening so they're water tight when closed.
In theory, you could jusr cut the hole in the hood, pop one of these in with it's gasket (like a rear pick-up window) and hook up a choke cable. They are spring loaded in a way so they don't get blown open/closed on the highway, but you could probably undo that for cable activation.
I looked some up on the web a year ago. I'll try to find them again and send the link.
Just a thought.
K.
Old Apr 26, 2002 | 10:12 PM
MustangGT221's Avatar
MustangGT221
I've got a brand new (but painted) 92-96 hood if thats anything you'd be interested. I got in an accident...so i had to buy this new hood, but then i got my ram air hood instead so this hood has been on my truck for a few months, thats it.
Primary rig is:
95' F-150 EB 300/6 5 spd with 4" Superlift, MSD, Ram Air, Gibson Exhaust, 32" BFG Muds
NEW PICS IN MY GALLERY!! :-)
Then theres:
88' F-250 Superduty 351 + c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 and a
3 spd column shifter. Top speed, 65mph, Go Baby Go!
The newest addition to the Ford family is a 99' Mustang GT 4.6L
Old Apr 27, 2002 | 12:41 AM
Ryan50hrl's Avatar
Ryan50hrl
Old Apr 29, 2002 | 04:51 PM
Chuck P.'s Avatar
Chuck P.
Thanks guys! Great ideas!
Yeti, thanks for the idea, I kinda cheaped-out though and used a piece of steel metal to "test" the install, slightly thicker, but would hold the very slight "bow" that the hood has. Worked out better than I thought it would! Water entering may still be a problem to work out, but thought I would look for or make flat covers with magnets, or the magnetic sign stuff, for when it's parked, if I go this way. If I can "liberate" our camera from my girlfriend for a day or two-it's ours, but mostly her's! I'll take some pics and post 'em, still want to get some pics of the finished install of the torque arm (which it 'tis correctly called!). Got Performance Unlimited to make me one from DOM tubing that matches the silver/gray finish of their trac-bar that I have on, works better than expected and looks good to.
K, this was such a great idea that I did check out several different places to see what was out there. Unfortunately, all had domes that seemed to stick up rather high and none were actually clear-if you know of a low-profile, less than 1" when closed, with a clear lens, please let me know, this would be the "ticket" as it were! Reason being, I can't really give up any visability over the hood, have 3" of lift with 35's and no real spotter-she's gettin' better, but these things take practice!
'Stang-Thanks a bunch for the offer, if I could make it fit the '79 I'd take you up on the offer just to have 2 hoods to play butcher with!! Only kidding-sort of! Again, Thanks to all Chuck
AXracer
26
Jul 29, 2023 10:54 PM
TexasGuy001
24
Aug 29, 2022 10:49 AM
WhatsAChevy?
15
Jun 16, 2016 01:31 AM
bubba_3711
25
Jan 19, 2012 10:04 PM
1994F2507.3L
Nov 27, 2010 04:23 PM
