Smoke Switch
Old Sep 20, 2008 | 07:35 PM
B_Thompson's Avatar
B_Thompson
Smoke Switch
I know that you can put a smoke switch on a motor with a waste gated turbo but can you put one on a VGT turbo motor, such as the 6.0. My dad wants to put one on his 04 truck for some fun. Any help would be great.
Thanks,
Blake
Old Sep 20, 2008 | 07:36 PM
riggz's Avatar
riggz
My truck has a smoke switch called the skinny pedal. Does he have his trucked tuned?
Old Sep 20, 2008 | 07:56 PM
B_Thompson's Avatar
B_Thompson
No...he doesn't want a tuner. I have tried to talk him into it but he says no. He just wants a easy way to let some smoke out on the little gassers around here.
Old Sep 20, 2008 | 08:57 PM
slowmans's Avatar
slowmans
you could put a switch on the vgt selenoid, but im not sure it will be a good thing for the turbo?????
Old Sep 20, 2008 | 10:55 PM
Benchwrench's Avatar
Benchwrench
he might need to ask this in the batman forum or maybe in the james bond one.
Old Sep 20, 2008 | 11:02 PM
UGA33's Avatar
UGA33
It can be done. I have seen one in person. Dont try to pull out in front of somebody b/c the truck wont get out of its own way when the switch is on! It will smoke like i freight train though if thats what you are looking for
Old Sep 20, 2008 | 11:07 PM
CaRKrAzEE's Avatar
CaRKrAzEE
what is a "smoke switch", how does it work, is it bad for the truck, and how do i get one? lol
Old Sep 20, 2008 | 11:12 PM
UGA33's Avatar
UGA33
All you do is tie into the VGT control wire with a switch so you can kill the power to the turbo thus not creating boost. With no boost, there isnt any air to clean the fuel which then gives you lots of black smoke. Someone correct if im wrong but that is the simple answer i think
Old Sep 20, 2008 | 11:17 PM
CaRKrAzEE's Avatar
CaRKrAzEE
thats not bad for the turbo?
Old Sep 21, 2008 | 09:43 AM
liv's Avatar
liv
why would it be bad for it? All your doing is preventing it from building boost. I would be more worried about all the unburnt fuel throughout the entire motor/exhaust.
Make sure he takes his cat off.
I don't really understand how hooking up a switch to the veins would do much though. You describing the turbo refusing to spool up and the truck just ******* down. The stock turbo isn't that big it should start to spool pretty quick with the veins wide open. There are plenty of guys running not vgt turbos that are bigger than stock and they say there's not much of a difference over stock. I can smoke out the block if I stomp on it from a dig I don't know why you would want to do anything more than that.
Old Sep 21, 2008 | 01:45 PM
unrulee's Avatar
unrulee
ROTFL !!!!!!!!!!!!!!!!!
Old Sep 22, 2008 | 12:25 AM
mxer0022's Avatar
mxer0022
personally i would think that the Inspector Gadget forum would have the best answer for this.
B_Thompson
Aug 23, 2012 01:59 PM
tbh219
6.2L V8
Apr 27, 2012 07:21 PM
Bladely
Nov 15, 2011 09:30 AM
blakeusa
Feb 22, 2008 01:30 PM
VR666
28
Jul 27, 2004 05:10 PM
