i need to know how tall,inside & outside diameter of the f100 springs? if theres a difference between the 2wd and 4wd label both please? also if you know the spring rate i would love to know them to?
That's the left side spring, it's a little lighter than the right side spring.
It theory I guess it's a good idea but in practice it ain't! :/
I replaced that spring with one from the wrecking yard that had the same
wire size as the right side and straightened my pickup right up, for the first
time since it was new! :)
YMMV :)
Like my 3/4" gasoline hose idea? ;)
Everyone that rides in my pickup comments on how great it rides.
235/85-16's load range E at 35 psi
