1970 f-600 dump with ignition problems
Old Sep 20, 2008 | 03:15 PM
CentralMassLandscape's Avatar
A few days ago i bought a 1970 f600 dump tuck with the 300 engine. It did have a slight misfire so i decided to change the plugs and wires to see if anything would change. I started it back up again and it was still misfiring so i checked to see if i had the sequence right and didn't mix up any wires ( i changed the plugs and wires one at a time so that i could keep the original order). after looking at the stamped sequence on the intake manifold and looking at the sequence on the distributor cap i realized that none of the number matched up. I changed everything and now the truck
Old Sep 21, 2008 | 09:11 PM
Freightrain's Avatar
Freightrain
What? Doesn't run?
Old Sep 22, 2008 | 08:27 AM
I drove it from my shop to my house to change the plugs and wires but I realized i had the cylinders numbered wrong in my head...i dont know what was wrong with me, it was a stupid mistake. The truck runs now but i have to have the choke half way out so it doesn't die on me. It seems really underpowered now too.
Old Sep 22, 2008 | 12:54 PM
Freightrain
Did you rotate the dizzy? Maybe the way they had it had the timing where they needed it? Have you put a timing light on it?
Sounds like it has fuel issues, but since you played with wires it's worse?
Old Sep 22, 2008 | 02:00 PM
Ya its definitely worse, i doubt it has enough power to even drive. Ill have to check the timing tonight even though i didn't intentionally mess with the distributor. I think youre right about fuel issues too because when i pump the gas its not so bad.
Old Sep 22, 2008 | 03:30 PM
Freightrain
If the timing is retarded, it will be real lazy and lack power. BUT, if the timing is good, then the fuel is the next thing to check. I just mentioned the timing since your working on that part. Might as well cover the bases as you go.
Old Sep 24, 2008 | 11:06 PM
packing45's Avatar
packing45
change the coil...
