rear end
Old Sep 25, 2008 | 08:55 AM
desoto dave's Avatar
desoto dave
rear end
for those that don't know,dont forget to check the breather for your rearend. it usually is the nipple piece attached to a hose that holds the junction block for the rear brakes on the drivers side axle housing.make sure they are cleared out by using compressed air. take the nipple out first so you don't blow debre in the rear. if not clear it will cause leaks,axle,seals,pinoin.i just got my 68 f350 and the hose was broke and the nipple was clogged with dirt causing the axles to leak.hope this helped someone
