get it out with some baeting and some bad words but i broke the vacume advance though but im putting a new msd or my friend has one from a 460 it should work in thanks for all the help
just a suggestion, but when I put my new distributor back into the hole, the alumninum housing is going to get coated with Anti-sieze. I don't care if it doesn't help, it sure can't hurt anything!!!
Try brake fluid instead of wd-40 and such. Put some brake fluid around the area where the distributor goes into the engine. Let sit for an hour or so and you should be able to turn it. Brake fluid is fantastic for loosening parts, just dont get any on yout paint.
I figure the way I'd do it is to take all the stuff out of the distributor so
just the aluminum shell and shaft are left and fill it full of crushed dry ice.
With gloves on...
While waiting for it to actually work, I'd be trying to twist the sorry sucker.
im from pa but live in tn now and you can't get it here in my town id have to drive an hour for some 3 days of lubing and it came out now im trying to retime it cant get the poping out thanks for the ideas i'm sure the dry ice thing would work its a used motor so im going to check everything out the weekend, when i got the truck the dist was all jacked up but it ran no power though it still runs but now power and alot of poping i have headers and staight pipes no mufflers saving for some flows 1 chambers thanks again
Maybe its just me but I had to read the last post three times to understand it.
I'm no english teacher but...
73Dentsidecustom - A little punctuation might help you to be understood better.
X2... except I'm still not entirely certain I understand it!
well, pounding or shoving on the vacuum advance actuator will only screw that up, and i just priced and purchased one today @ $40.00.....maybe 'better idea' to remove the advance actuator, which will much more readily allow for the 'west virginia' idea (pipe wrench)....agree you want to first break it loose by turning
