IDM Mod...AGAIN!
Old Sep 19, 2008 | 11:11 PM
schlepprock250's Avatar
schlepprock250
IDM Mod...AGAIN!
OK...Was it ever decided if the 140 mod gives the same effect with the DP in what ever setting?Ive searched and cant find a straight answer.I would like to do this mod too but just want to know what the thinks are about the DP.
Thx...schlepprock
Old Sep 19, 2008 | 11:17 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Short answer. Yes.
It does the same thing regardless of what chip you have in it. May not make a difference you can feel, but run some before and after times and you'll see it.
Old Sep 19, 2008 | 11:19 PM
mueckster's Avatar
mueckster
I posted my 0-60 mph times before and after the 140v IDM mod about 5 months ago. I only tested it in the 80e setting. There was a definite improvement in throttle response and low end torque. I would say that there has been an improvement in all the other settings also.
Old Sep 19, 2008 | 11:35 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Wanna trade a 140 for your stock 120?
Old Sep 19, 2008 | 11:39 PM
cookie88's Avatar
cookie88
FTE Emeritus
What do you need an IDM for Kris?
zack7.3's Avatar
zack7.3
If Phil doesn't want it, I might be your huckleberry.
Old Sep 19, 2008 | 11:43 PM
PowerstrokeJunkie
Apparently my truck didnt like 140 volts of juice.
Old Sep 19, 2008 | 11:44 PM
zack7.3's Avatar
zack7.3
You really think thats what your problem was?
Old Sep 19, 2008 | 11:47 PM
cookie88's Avatar
cookie88
FTE Emeritus
Doesn't appear that it liked extreme programming, high pressure oil, or large injectors either.
Old Sep 19, 2008 | 11:48 PM
PowerstrokeJunkie
I could only hold about 2600psi. ??? and Jody "says" the tuning was "very conservative". The injectors weren't large, they were only 160cc. You want large, ill show you "large". (lol)
Old Sep 19, 2008 | 11:56 PM
cookie88's Avatar
cookie88
FTE Emeritus
True. Read several posts where PMR guys have blown motors idling in the driveway, or just cruising down the motorway. No telling how long that motor has been damaged.
Honestly....I suspected that motor was on it's way out when you were having all the issues with the big oil pump. I think maybe the new combination of power parts just put it over the top.
With you popping at 370 and Jeremy at 430.......Hell I don't know. Makes one question one's faith in our engine of choice.
Old Sep 20, 2008 | 02:50 AM
UP_There's Avatar
UP_There
it was probably your new habit of playing with sleds
Old Sep 20, 2008 | 06:14 AM
PowerstrokeJunkie
Is it still a habit if you only do it once?
Old Sep 20, 2008 | 09:54 AM
UP_There's Avatar
UP_There
I thought you were pulling the sled the same night your engine grenaded? Just on the way home Sorry for the hijack Phil
Old Sep 20, 2008 | 09:59 AM
UP_There's Avatar
UP_There
Thx...schlepprock
I have read all about this topic....and have seen the results with documented times where it showed improvement......HOWEVER, I can't find it, but I also remember reading a post from Jody....I think it was either Jason or Brandon that asked him at Smokin about the IDM.....he reccomended AGAINST it. Sorry if I'm wrong on that info......but that's what I recalled lol
