Well firts thank for the answers and sorry to bother you so much but belive me your my last hope before they overhaul the engine
I call excell they told me they take out the turbo and there was some dirt inside but they think its normal but they find some space more than normal in the axle of the turbine and they sent to a especial place here and they are going to checked
Sounds like an EGR and turbo issue. The EGR is probably gummed up an sticking, also if the truck sat for a while then the veins in the turbo are stuck, also the unison ring could very well be bad also.
The veins are what conntrol the amount of boost that the turbo will produce. These trucks are noted for this. Like I said if I let mine sit for a week or 2 this will happen to me. I just drive it and get it up to temp and all is good again.
they put another turbo in my truck they tried a 2004 f250 and they told me the that the truck stay low and they are going to do more test to verify everything but they dont think know is goin to be the turbo any knew qs???
check for air leaks on intake plumbing, as well as exaust leaks. with boost that low the intercooler could be damaged. sometimes the end caps of the intercooler can come off
Well they change the turbo they change another sensors and they told me that the car have more power but when they went back to the dealer the car suddenly stop again when they reach the dealer and scanned the scanner says that have problem with 4 injectors i went to the dealer today to see it and they shoow me the engine and the 4 injector that have problem know are the left ones and this is why the engine stopped
Clues Again????
