Sponsored by: Real Truck
Idle problem
Old Mar 23, 2012 | 05:11 PM
Turkeybird77's Avatar
Turkeybird77
Idle problem
I have a 99 superduty 5.4 5speed manual 4x4. It has a idle problem that started when I guy hooked up a scanner and tried running a test. The truck idled up to 1500 and the scanner shut down and it has idled high since. It also idles up when driving while you switch gears idle jumps when clutch is pressed and it's slow to drop down. Have checked all vacuum lines intake and Pcv hose also changed iac tps egr valve dpfe and cleaned mass air
Old Mar 23, 2012 | 09:01 PM
jh818's Avatar
jh818
How about the IAC valve?
Old Mar 23, 2012 | 09:11 PM
Turkeybird77
Yeah I did. This thing is driving me crazy.disconnected battery cable today when I got home from work going to hook it back up in the morning mayb that will help????
kjs5055
May 8, 2017 01:37 PM
hillbillyford
1983 - 2012 Ranger & B-Series
16
Sep 2, 2010 08:24 AM
stutterstan
Jan 30, 2005 03:09 PM
First 250
Modular V8 (4.6L, 5.4L)
Nov 14, 2004 10:48 AM
