Diagnostic port
Old Sep 19, 2008 | 02:41 PM
AndysFords's Avatar
AndysFords
Diagnostic port
My truck has been running strange, at first it would lose power and just sit there and idle for a few seconds with the check engine light on, then run normally, now it quit all that crap, but it has absolutely no pull, it won't get up and go until about 50 mph, then it just takes off all at once??????? I went have it plugged in, the computer wouldn't read anything. The man said something was wrong with my diagnostic port. What would cause this? Can it be fixed easily, or will it have to go to Ford.
Old Sep 19, 2008 | 02:47 PM
Action4478's Avatar
Action4478
May need to check the fuse for the lighter & aux plug ...
I think they are all on the same fuse ...
Old Sep 19, 2008 | 02:49 PM
Cuda_jim's Avatar
Cuda_jim
Gotta be sure the scanner is compatible with a diesel.
There is a step by step procedure for a dead OBD2 port.
I'll see if I can find it.
Old Sep 19, 2008 | 02:53 PM
Neal 97 250's Avatar
Neal 97 250
I wonder if the EBPV is acting up. Unplug it and/or wire it open. See if that helps any.
Old Sep 19, 2008 | 03:00 PM
Cuda_jim's Avatar
Cuda_jim
You're too fast for me Rick
Fuse #16 powers the DLC
Horn & Cigar lighter too
Old Sep 19, 2008 | 03:14 PM
Action4478's Avatar
Action4478
Your info was better though.....
Old Sep 19, 2008 | 09:43 PM
AndysFords's Avatar
AndysFords
EBPV?????? Can you put that in english for those of us who don't speak powerstroke? Please note that while I can fix anything on an old 7.3 or 6.9 IDI, I know absolutely nothing about a Powerstroke. The lighter plug works.
Old Sep 19, 2008 | 09:47 PM
884x4broncoII's Avatar
884x4broncoII
ebpv exhaust back pressure valve its right behind the turbo inline on the exhaust. also not all scanners will work with the 7.3 you have to make sure you have one that is compatible
synvolk
Mar 30, 2014 09:34 PM
hopewell
Oct 19, 2013 08:57 AM
Franko72
Mar 12, 2013 12:44 PM
muddog95
2004 - 2008 F150
Sep 27, 2010 08:07 PM
fourdoordemon
Jul 24, 2009 12:59 PM
