Offroad & 4x4
4x4 not working...
Old May 17, 2002 | 05:36 PM
billbob's Avatar
billbob
4x4 not working...
I was able to purchase a 1979 F150 Custom really cheap. After getting it home I noticed that the 4x4 shift on the floor was wobbling. I opened up the floor panel and found that it is connected but not really working? Is this easy to fix? where would I go to find out informtion on putting this back together? Any suggestions?
Thanks,
Old May 22, 2002 | 09:40 PM
mudinford's Avatar
mudinford
4x4 not working...
Would suggest a trans shop take a look at it if you have never broken down a trans or t-case....like me! haha.....anyway....hope you get it working...i would help if i could see it!
Dan "Mudinford" MacDonald
'86 Ford F-150 4x4 w/ a spooled mono Dana 44/a spooled 9" running 38" TSL. 300ci, Clifford Intake and Headders, .05" Milled Head with SBC valves, port work
500 CFM Edelbrock, Clif. 290* cam with Rhoads lifters, .040" TRW Pist w/ Moly rings.
Future plans: A draw through Twin(or big single) Turbo setup (to help with the upper end)
Old May 23, 2002 | 09:53 AM
AZ4x4f150's Avatar
AZ4x4f150
4x4 not working...
It could just be the plastic bushings they put in the liinkage that go bad over time especially in climates where you have snow the road salt deteriorates them over time. with these bushings worn out it can make a transfer case hard to shift. If you are getting the transfer case in gear and it is not moving the front driveshaft well then you might be looking at a rebuild on the transfer case
Old May 23, 2002 | 11:26 AM
rabidranger's Avatar
rabidranger
4x4 not working...
