I recently opened the air cleaner and heard a moderatley heavy clooping sound from the intake. Now I can only here this sound with the lid off. Im guessing it is a bent valve but I also am experienceing low oil pressure from a Autometer electric gauge. It reads zero at idle but I still have oil come though the rockers. It doesn't squirt like I thought it should but I still have oilling. My question is this cloop cloop sound normal? I have checked other motors and heard the sound or is the CDR or maybe rod knock. I am a little nervous because I just disassembled a junk yard 6.9l and found the rod bolts finger tight and was wondering if this is a common problem, should pull my pan and check the bolts?
By the way it is a 1986 F-350 crew, duelly, 4X2, w/ 6.9l, 4-speed, 115K miles.
Sounds like a worn guide on one of the intakes. And the only real way to check the rod bolts is to pull the engine. May want to do both jobs with the engine out.
mine has a loud cloping sound with the intake off at idle. Kinda goes away with throttle. These are noisy engines without the intake and filter on. Although, I don't know how noisy yours is and how long its been making noise. Oil pressure does sure seam low though if your guage is accurate.
Our oil pressures are 10 at hot idle and 40-70 at 3000+rpm......
You will hear the pistons sucking the air in...... a muted woof is normally the case. If an intake valve is the problem.... normally a loud woofing noise is present due to combustion returning to the intake.......
A chuffing noise from the exhaust pipe is a bad exhaust valve.......
