Blow by
Old Sep 18, 2008 | 06:16 AM
just another truck's Avatar
just another truck
Blow by
IF my memory serves me, Blow buy is cause by the rings, this could be caused by egg shape cylinders, busted ring, ect..So, If I was able to pick up a motor with blow by, would it be worth the time to rebuid. Next, I have not heard anyone here talk about boring a cylinder in the 7.3, so do you resleave these things, or what would be the standard repair??
Old Sep 18, 2008 | 06:23 AM
Kwikkordead's Avatar
Kwikkordead
Blowby is mostly caused by the rings and also a very small part by the valve guides.
Given the track record cracked blocks next to the freeze plug and along the top of the oil pan, I think it is best to just go by a new block.
Those new crate engines don't do much for me because I think they have PMR's.
Or buy a crate engine and swap out the rods before you even install the engine in the truck.
All those are pretty expensive options, however.
Old Sep 18, 2008 | 06:38 AM
just another truck
Thanks Dan, I was thinking I could get the block cheap, and work on it over time. But, since Murphy and I have such a long standing realtionship, I thought I should ask.
Old Sep 18, 2008 | 12:08 PM
John311t's Avatar
John311t
I got my old block in the garage that might go this route, but its going if it does, its going to be a built bottom end, not stock lol.
The block can be punched out until I think its 30(I think its 30) over before a sleeve. I know if its only needs 10 over to get cleaned up, you will not need a sleeve.
Its not worth it, unless you want to go built bottom end to do the work yourself really. There is a place in Texas that is a motor exchange, you sent your motor, they send you a rebuilt one, I believe there cost is 2900$ with core. This is a long block though, with heads. IMO
Old Sep 18, 2008 | 12:17 PM
just another truck
It was a motor I was thinking of doing from bottom to top.. at the same token, as I was thinking of this, it was a matter of when would I do it...
