burnouts...
Old Sep 18, 2008 | 10:29 PM
Dave Sponaugle's Avatar
Dave Sponaugle
1973 model Z1 900 bored out to 1127 and still kicking butt.
Old Sep 18, 2008 | 10:32 PM
Blueovals&Blacksmoke's Avatar
BAD ***!!!!!
ill play this game all day long
Old Sep 20, 2008 | 07:53 PM
bc6.9's Avatar
bc6.9
And black cars look better in the shade....cheap tires do the best burnouts...I don't have cheap tires...but I have one FAST truck!
So what's your point....if you can smoke your back tires you ???? WHAT?
Old Sep 20, 2008 | 10:04 PM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
Answer
Ummm, burn high dollar rubber and fuel?
Old Sep 20, 2008 | 11:23 PM
Dave Sponaugle
I guess I must be old.
My point was there are lots better machines more suited to doing burnouts.
I break enough stuff under normal driving conditions.
So you go out and get the rear tires spinning on a close to 8000 pound truck, the rear axle starts hopping, there goes a drive shaft, transfer case or rear axle.
The cheapest repair on that list is 300 for a new driveshaft.
Now not only am I laying out cash for a repair, but I am also walking to work till I get it fixed.
To each his own, but burnouts are not something I try to do.
Cheap tires, never on my truck, I never know when I will have to drive through some mud pit or climb some steep slick hill.
Mud tires cost to much to turn to smoke, they already wear out way to fast.
Old Sep 20, 2008 | 11:34 PM
Dodge/Cummins's Avatar
Dodge/Cummins
You are getting old judging by that statement,! But it's also true.
Maybe older and wiser would apply here.
Old Sep 21, 2008 | 12:18 AM
im trying to make a moderate hp diesel so i can show up the BB chevy's that win the burn out contest every year, ( winner gets a free set of tires from schwabs) second place gets 50 bucks lmao big difference in worth
Old Sep 21, 2008 | 12:45 AM
82F100SWB's Avatar
82F100SWB
That's the kind of thing a juiced up 6.9 can do to driveline parts without abuse, just making the truck work for a living... Last summer it ate 8 u-joints at the yoke on the rear diff, and busted the yoke... Mind you when I was towing with it, I was probably 18K at the lightest...
If You want to win a burnout contest, traction bars, locked diff, upgraded drivetrain, etc are necessary, but, if you are blowing smoke out the exhaust, route it out in front of the wheels so it mixes in with the tire smoke... From my understanding of a burnout contest, more smoke = better, so....
Old Sep 21, 2008 | 12:51 AM
yes the more smoke = better but its also graded on a couple other qualitys,
ease of burn out and a few other things, but if you mix soot from the exhaust it makes for a worse burnout because soot is heavier than air and it pulls the tire smoke down to the ground
Old Sep 21, 2008 | 05:10 AM
FORD MEGA CAB!!!
A new set of tires? I wonder if they would do 6 tires for a dually?
Nice yoke on that diff there. Makes me want to keep a spare along with my spare U-joint in the back seat.
Old Sep 21, 2008 | 11:23 AM
gonecrazyi's Avatar
gonecrazyi
My cousins 94 f350 single cab with a 4 in lift and 285 street tires(has another set for the mud) can easily roast the back passenger tire. Just put the shifter into 1st and hold the brakes. The truck has about 180,000 on it and still kicks out the power with no turbo.
Old Sep 21, 2008 | 01:05 PM
^^^ thats with an open diff through, i have a locker of some type in the back be it a detroit or posi idk but both mine spin
Old Sep 21, 2008 | 02:24 PM
  #28
Dave Sponaugle
Yeah, I have a couple yokes that look like yours.
I also have a couple drive shafts that aren't much better.
And I have replaced a transfer case that split right down the middle.
All that with normal driving, no spinning tires or speed shifting type driving style.
Old Sep 21, 2008 | 04:49 PM
  #29
so i should i put some money into our dodge? ATS arc flow intake, ATS pulse flow exhaust manifold stright pipe it and put a chip in it.
Old Sep 21, 2008 | 04:54 PM
  #30
our 89 F-350 460 4 speed did that to the rear yolk and the slip yolk at the same time... 3 u-joints and a couple yolks later its good as new
