Offroad & 4x4
high angle driveshaft
Old Jul 9, 2002 | 02:48 PM
1970f2504x4's Avatar
1970f2504x4
Old Jul 17, 2002 | 11:30 PM
AggiePSD's Avatar
AggiePSD
does any one know of a good builder of high angle front axle driveshafts? My upper cv joint is binding (because of lift)and I want to either replace it with a better shaft or possible machine it. Is it possible to machine off a little on the end of the yokes so they dont hit, or is this not a good idea.
thanks in advance,
travis
Old Jul 18, 2002 | 10:58 AM
Playtime's Avatar
Playtime
Check out this sight http://highangledriveline.com/
Old Jul 18, 2002 | 02:10 PM
marriedguy1's Avatar
marriedguy1
My buddy trimmed a little off his yokes when he put on a 6 inch lift last year. He wheels his truck pretty hard and has not had any trouble with it yet. A little scary to do, but he was trying to do it cheap and it's hard to beat a grinder when price is your motivation.
Old Jul 18, 2002 | 10:22 PM
AZ4x4f150's Avatar
AZ4x4f150
Arizona driveline makes a high angle drive line that can handle up to 80 degrees and still spin freely I will find there web address and post it for you in this post
Old Jul 18, 2002 | 11:13 PM
AggiePSD's Avatar
AggiePSD
thanks for the help guys. I will check out both sites as soon as possible to get an idea on the prices. 80 degrees sounds awesome! if they are a little on the pricey side, I'm sure they are, its comforting to know someone else has done the cheap fix.
Old Jul 19, 2002 | 02:23 PM
Maxduty's Avatar
Maxduty
I got the high angle end from Arizona for around 400 I think. I'm going to have the shaft made locally, so I just bought the 80 degree end. As for your stock driveshaft, you will need to round off all of the squared edges near the u-joint caps. I did mine with a die grinder and a carbide cutting tip. Make sure you get all of them though, or you may get a hard to locate thump in 4 wheel drive.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
