need help
Old Oct 13, 2008 | 06:27 AM
subford's Avatar
subford
Originally Posted by mascher
Did the line test everything looked good,however it is smokin hot at the selenoid when i crank it.I can't find the attachment button to post pictures of the area and don't use public places like photobucket to host.Any other thoughts.Some friens mentioned theres a rotor under the distributer that ma have fried.M
What do you mean by line test?
How long are you cranking it when it gets "smokin hot"?
Is the test light flashing at the tach side of the coil when you crank it?
Old Oct 13, 2008 | 06:35 AM
mascher's Avatar
mascher
crank it for maybe a minute.The cord from the battery at the selenoid has actually melted some.I will look at your line drawing and get one of the kids to help me check the tach side but that would be later on (school).M
Old Oct 13, 2008 | 06:37 AM
mascher's Avatar
mascher
line test = continuity to check for damaged lines.M
Old Oct 13, 2008 | 06:54 AM
subford's Avatar
subford
What size engine do you have?
You may have a bad (draging) starter?
Does it crank slow?
Old Oct 13, 2008 | 07:03 AM
mascher's Avatar
mascher
no the starter turns fine when the battery is up.It has a 351 engine.M
Old Oct 13, 2008 | 07:14 AM
subford's Avatar
subford
I would limit my cranking to about 15 seconds at a time then and let it cool before retrying.
We need to know if it is flashing the test light before we can help you much more.
Old Oct 13, 2008 | 07:22 AM
mascher's Avatar
mascher
ok will do later and get back to you.Thanks so much.M
Old Oct 13, 2008 | 02:38 PM
81Ford_Stepside's Avatar
81Ford_Stepside
Fuesable Link
Test The Small Fuesable Links By The Silo. They Will Be Down On The Fender Well.
Old Nov 8, 2008 | 05:17 PM
mascher's Avatar
mascher
ok we have checked every fuse we can find and every fusible link.the solenoid,ignition module,and coil all check out.we are getting no spark to the plugs,Thoughts and suggestions appreciated M
351slug
Offroad & 4x4
Mar 16, 2013 10:11 PM
Irish816
Offroad & 4x4
17
May 19, 2010 08:08 AM
Offroad & 4x4
Dec 9, 2006 09:03 PM
4x4x4x4
28
Dec 16, 2002 01:54 AM
CustomCab4x4
Feb 3, 2002 02:20 PM
