Trouble Code p2285
Old Sep 15, 2008 | 05:56 PM
714x4's Avatar
714x4
Trouble Code p2285
I have a 2004 F-350 with the 6.0 powerstroke. I bought this truck a little over a month ago, it had a check engine light on and idled rough when the engine was cold. I checked the code it read p2285 Injector pressure control circuit low. Now that the weather is sarting to get colder it doesn't want to start, when it does it makes alot of noise and sounds like it is only hitting half the cylinders. I have researched this topic on the site but the infomation is for the 2003 trucks and it seems that the sensor location has been moved as I can't seem to find it lol. Any information on how to replace the senor in an 04 would be appreciated
Old Sep 15, 2008 | 06:47 PM
bismic's Avatar
bismic
04 (and up) ICP sensor location change - passenger side valve cover (production beginning 9/29/03).
Edit - deleted the 2003 info after I read the post thoroughly.
Old Sep 15, 2008 | 07:10 PM
714x4's Avatar
714x4
Thanks for the quick reply. I've looked at the pictures many ties already and looked again still couldn't find the sensor so I checked the build date-7/03. Turns out it's before september so it's an 03 engine after all, explains the troubles i've had. Sorry to ask this but where exactly is the sensor on an 03?
