Loose Steering Correction Thread
Old Sep 29, 2008 | 02:38 PM
Monsta's Avatar
Monsta
Sit. Stay.
Where are you looking at the play?
Adjusting the box will only fix play between the steering shaft going in and output shaft to the pitman arm. If you can turn the wheel and the pitman arm doesn't move then that is what you adjust. Sometimes it doesn't work. You can only adjust a certain amount until you reach the point in which the steering gear needs to be replaced/rebuilt.
Keep adjusting in 1/4 turn increments. It tighten up.
How much play do you have in the steering wheel? Should be around an inch.
On another note: I got my blender. Smoothies anyone?
Old Sep 30, 2008 | 08:40 AM
DaveandJennyP's Avatar
DaveandJennyP
Originally Posted by Monsta
Loosen set nut.
Turn Allen headed bolt COUNTER-clockwise to tighten up steering lash. (Little movements)
Retighten set nut.
Maybe I'm wrong but isn't Counter-clockwise the wrong direction for turning the Allen head bolt???
Old Sep 30, 2008 | 09:49 AM
carrnut's Avatar
carrnut
I was kind of wondering the same thing since the locknut tightens in the standard clockwise fashion doesn't that mean that the threads on the bolt are also right hand?
Old Sep 30, 2008 | 11:08 AM
pdx02's Avatar
pdx02
Can someone confirm the direction of rotation please. I would hate to think I have been actaully making it worse
Old Sep 30, 2008 | 11:53 AM
APEXDUCK's Avatar
APEXDUCK
It is clockwise, NOT counter clockwise. It is a standard theaded bolt and you are tightening the gear engagement when you screw the bolt in further. Thus if you over tighten, it will create too much friction and premature wear will result. Start with 1/8 of a turn and go more if needed. It only takes a couple of minutes to to this. I used a box end wrench and an allen wrench. Be sure to place a reference mark on the bolt (allen screw not the nut) so you know how much you moved it.
APEXDUCK
Old Sep 30, 2008 | 12:03 PM
pdx02's Avatar
pdx02
sounds good. Will be working on it tonight!
Old Sep 30, 2008 | 01:02 PM
Monsta's Avatar
Monsta
Sit. Stay.
Ya know...I made an error there! Not sure how I didn't catch that. *slaps head*
Lefty-loosey, righty-tighty.
My apologies.
Old Oct 4, 2008 | 11:33 AM
chazman's Avatar
chazman
Glad you realised it was backassed. I though to myself "that has to be wrong." But what do I know. Clockwise to tighted the steering box. Make sure you hold the allen in the fixed position while you tighten the outer nut.
Old Oct 6, 2008 | 03:06 PM
ECA's Avatar
ECA
Since I bought my X it has had at least 4'' to 6'' of play in the steering. Not a big deal, just thought it was because of the 35'' tires.
Finally, last night I had my buddy who does all the work on my truck adjust the steering.
He went 1/4 turn no change, another 1/4 no change, another 1/4 felt a little better, one last 1/4 turn and WOW, what a difference !!!
Thanks to all for the info. You do turn it Clockwise to tighten.
Old Oct 6, 2008 | 03:12 PM
pdx02's Avatar
pdx02
I have been working on mine and think that my next quarter turn is going to find the sweet spot.
Old Nov 15, 2008 | 08:09 AM
H1449-6's Avatar
H1449-6
I've tightened mine half a turn about four times now and I'm still not happy with the amount of slop I have in the wheel.
How tight can I go with this thing?
Old Nov 15, 2008 | 10:11 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy
H1449,
You've turned the allen screw clockwise 1/2 turns four times for a total of two full turns clockwise on the allen screw?
When you make the adjustment of the allen screw...are you holding that tight in place while you snug the jam nut? If not you will be loosing up the steering (i.e. turning the allen screw counter clockwise) as you tighten the jam nut.
If you truly have turned the allen screw 2 full turns...I'd say you very likely have something else going on. I'm not sure I have ever read any one on here say they turned it that much. usually 1/2 to 1 turn is what I remember reading.
Oh yeah...how bout some reps for the guy that took that photo...I snapped that photo and posted it in February of this year for someone on here and I'm glad it is getting some press! With all the photos I've posted...I normally get about 500-1,000 hits to my webshots page per week!!!
Joe.
Old Nov 15, 2008 | 04:41 PM
  #28
H1449-6's Avatar
H1449-6
Originally Posted by X_Hemi_Guy
H1449,
Yes and yes.
Maybe my expectations are too high. I'm turning the steering wheel a good two inches before the wheels move.
Old Nov 15, 2008 | 08:04 PM
  #29
JaySVX's Avatar
JaySVX
I think this is exactly what I am looking for. I picked up my Ex today, and driving back on the highway, I could turn my steering wheel a full inch in either direction before it would start to turn the wheels, so minor corrections to steering required much more turning of the wheel than necessary, quite annoying. If this will fix that, I may go out tonight and get that tightened up.
Old Nov 16, 2008 | 09:54 PM
  #30
CanadianSmokie's Avatar
CanadianSmokie
The steering box adjustment will tighten play between the steering wheel and pitman arm (5/8 wrench, 3/16 allen key) but the need for constant correction on the highway is more than likely because your caster angle is too negative (or is that positive ). A set of caster/camber shims set to max. caster angle will greatly improve stability of steering at speed.
Metalhead47
Jan 20, 2014 04:58 PM
F-250 restorer
Jan 22, 2013 08:38 PM
conoso
Jun 8, 2012 12:26 PM
weekendwarriorfsw32
Dec 2, 2010 06:44 AM
