conflicting information Need Help
Old Sep 14, 2008 | 09:19 AM
twisted_axel's Avatar
twisted_axel
Just bought another 70 series truck, this one is alittle worse of than the other one i bought. Heres the problem all stickers under the hood point to a 429-4v but the manuals i have say that it was not an option, were there 429's put into this great line of trucks and if it's not a 429 how do i tell what engie it really is? The vin code suggests its a 360 but how can i identify it for sure?
Old Sep 14, 2008 | 11:02 AM
80F100man's Avatar
80F100man
The 360 was the norm for engines, not a 429 in a truck that I know of, am I right number dummy?? Let us know Bill, will ya?
Old Sep 14, 2008 | 11:32 AM
Dr. Dirt's Avatar
Dr. Dirt
NumberDummy (Bill) is on vacation for a couple weeks.
no a 429 would not have been in a truck. if the vin says 360 and that's the orignal vin tags that came with the truck then yes the 360 came with the truck. it is very likely that the engine was swapped in when the 360 was tired. to tell if it's a 429 for sure you can count the number of valve cover bolts. I'm not sure how many for each engine. search the forums and you'll come up with something.
70 series........this forum is only from 73-79, what year truck did you buy?
Old Sep 14, 2008 | 11:46 AM
77f2504by4's Avatar
77f2504by4
to my knowledge, NO 429 was EVER putt in a truck 2 or 4 wheel drive. but i could be wrong.
Old Sep 14, 2008 | 11:50 AM
Dr. Dirt's Avatar
Dr. Dirt
I think you're right
Old Sep 14, 2008 | 11:53 AM
77f2504by4's Avatar
77f2504by4
i'm not familiar with the 60's trucks, so maybe back then they had them, but i doubt it.
Old Sep 14, 2008 | 11:57 AM
Dr. Dirt's Avatar
Dr. Dirt
well I do know that's one of the engines that they put into like the 428 and 429 Cobra
Old Sep 14, 2008 | 12:32 PM
fmc400's Avatar
fmc400
MSEE
A 429 would have been a swap because they did not come in trucks. To tell it apart from a 460, you'd have to measure the stroke.
Old Sep 14, 2008 | 03:17 PM
twisted_axel
Dr Dirt
It is a 1975 F250 Super cab 2wd
70 series........this forum is only from 73-79, what year truck did you buy?[/quote]
Old Sep 14, 2008 | 05:59 PM
Dr. Dirt's Avatar
Dr. Dirt
ok, so the easiest thing to do is to count the number of vavle cover bolts.
twisted_axel, do you have any pics of the truck?
Old Sep 14, 2008 | 08:47 PM
twisted_axel
I do not currently have any pics, but I will post them tommorrow after I take some( I bought it at an auction so i havent been able to bring it home yet ( it doesn't run yet) I should be able to bring it home tommorrow, but we'll see)
Old Sep 15, 2008 | 09:49 PM
twisted_axel
DR. Dirt here is a Picture that you were asking about
[/IMG] 1976 FORD F250 SUPER CAB (POSS 360 ENGINE)
Old Sep 16, 2008 | 08:31 AM
twisted_axel
Yes i have the VIN its listed as a 1975 F250 The vin decoder on this site says <TABLE style="BORDER-RIGHT: #990000 1px solid; BORDER-TOP: #990000 1px solid; BORDER-LEFT: #990000 1px solid; BORDER-BOTTOM: #990000 1px solid" width=600 align=center itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD style="PADDING-LEFT: 55px" colSpan=2 itxtvisited="1">Your Model Year is July 1974.</TD></TR><TR itxtvisited="1"><TD bgColor=#0099cc colSpan=2 height=1 itxtvisited="1"></TD></TR><TR itxtvisited="1"><TD style="PADDING-LEFT: 15px" width="40%" itxtvisited="1">Truck Series:</TD><TD itxtvisited="1">F250 2 Wheel Drive</TD></TR><TR itxtvisited="1"><TD bgColor=#0099cc colSpan=2 height=1 itxtvisited="1"></TD></TR><TR itxtvisited="1"><TD style="PADDING-LEFT: 15px" itxtvisited="1">Engine:</TD><TD itxtvisited="1">V8 - 360cid, 2BBL carb</TD></TR><TR itxtvisited="1"><TD bgColor=#0099cc colSpan=2 height=1 itxtvisited="1"></TD></TR><TR itxtvisited="1"><TD style="PADDING-LEFT: 15px" itxtvisited="1">Assembly on:</TD><TD itxtvisited="1">Kansas City, MO</TD></TR></TBODY></TABLE>
The Valve cover bolt count is seven (three top four bottom) the other posts indicated that the 429/460 had seven valve cover bolts, but i have not been able to find any info on the difference between the two motors except the stroke. is there any more information i might be missing to identify the difference between the two?
Old Sep 16, 2008 | 11:51 AM
Blue Bomber's Avatar
Blue Bomber
you can get the stroke with a coat hanger . bend the hanger straight, take out a spark plug, insert hanger into spark plug hole, turn the engine over by hand.
Old Sep 16, 2008 | 12:45 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
What letters are stamped on the head above #2 or 3 or #6 or 7 exhaust ports? They might say something like D0VE or D3VE. Id bet someone swapped this motor out of an old 429 T-bird. Do the valve covers say "ThunderJet"?
