Upgrade my heads
Old Sep 14, 2008 | 06:58 AM
agthomas2's Avatar
agthomas2
Upgrade my heads
I have a 1977 f150 with a 302, i'm looking to upgrade my heads and install a hotter cam. I'm been reading threads about valve clearance. I'm trying to figure out if I can use the heads with a 2.02 intake valves. The cam I am looking at has a lift under .5
Old Sep 14, 2008 | 08:59 AM
77f2504by4's Avatar
77f2504by4
you should try the specific engine forum and you'll get better responces!
Old Sep 14, 2008 | 05:05 PM
rickh51's Avatar
rickh51
If your engine is basically stock, except for the cam, you should probably stick with a 1.90" intake. The 2.02's would be overkill. Would most likely lose some low end torque and throttle response. Anything else done to the engine?
Old Sep 15, 2008 | 02:21 PM
agthomas2's Avatar
agthomas2
I have added and Edelbrock Performer intake and 600 series carb.
