Sponsored by: Real Truck
How to clean-out a hydroboost
Old Sep 13, 2008 | 01:09 PM
g60patrol's Avatar
g60patrol
I've done some searching but can't find quite what I'm looking for. I was grinding next to it before i realized the hoses were off...so there's some metal shavings in the threads. I've taken it apart and don't see that any got inside, but I want to be sure it's clean before I put it back together. So my question is: What product should I use to spray out the inside, solvent? brake cleaner? carb cleaner?
Thanks in advance!
Old Sep 14, 2008 | 02:41 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Flush it with ATF maybe?
I wouldn't use any solvents or cleaners because of the seals.
Old Sep 14, 2008 | 02:46 PM
zx250's Avatar
zx250
Of the next Riffraff East
You could do a flush and keep if from returning the shaving to the pump.
Old Sep 14, 2008 | 06:49 PM
g60patrol's Avatar
g60patrol
thanks for the responses. I checked all the innards over real close and didn't see any sign that metal shavings/dust had got past the pressure or return fittings. So I just cleaned the threads from the inside out, wiped everything down, and put it back together. This system is in a rock crawler and will be inline with full hydraulic steering; so I thought about attaching a magnet to the cooler/filter to catch and rouge particles.
MattMac
May 24, 2017 09:44 AM
Kyle Wood
Oct 30, 2016 06:52 PM
blk450er
Sep 14, 2015 11:05 PM
meck1
1983 - 2012 Ranger & B-Series
Sep 15, 2010 03:59 PM
Kep4
All Things Towing
18
Nov 22, 2008 02:47 PM
