Explorer 4WD Shift Control Module
Old Sep 13, 2008 | 12:45 PM
confer1's Avatar
confer1
Where is the shift control module located on a 1997 Explorer? My Chiltons doesn't refer to it
I looked in 2 places behind glovebox -No and in the left wheel well(where the keyless remote control is located) - No.
Also, I have the 4WD High/4WDLow panel lites flashing 6 times about every 2 minutes. Transfer case motor stays in 4WD high postion. Will not go to the neutral (2WD position). Motor will move to the 4WD low position and back to the 4WD High. It will not go to the 2WD (4WD disengaged) position.
Old Jan 26, 2009 | 06:50 PM
confer1's Avatar
confer1
I changed out the sensors for both axles and that fixed the problem. I figured this was long enough to validate the repair.
Jack Peterson
Dec 27, 2016 12:51 PM
orange1954
Oct 2, 2016 10:04 AM
underdogl3
Feb 18, 2016 07:00 PM
Shannon Duggan
Sep 7, 2015 01:09 AM
agsmv1
Jun 4, 2015 02:45 PM
