Battery Death
Old Sep 13, 2008 | 08:38 AM
scatgo's Avatar
scatgo
Battery Death
I installed a new sound system in my truck last week. I killed the batteries a couple of times in the proses. Ever since the batteries would die real easy. A couple of nights ago I turned on the headlights for just a minute so I could find something in my garage and of course in would not start after having the lights on for just a minuet. Yesterday at work I had the radio on for a minute or two and when I was going to go home for lunch the battery was dead. Looks like it is time for a new battery but how do I test to make sure it is not the alternator? Any opinions on die hard batteries?
Old Sep 13, 2008 | 09:06 AM
scatgo's Avatar
scatgo
Is there any way to test to make sure the new radio is not drawing current with the radio and truck off?
Old Sep 13, 2008 | 09:07 AM
fishmanndotcom's Avatar
fishmanndotcom
if you can get the truck cranked autozone will test your battery and alt free of charge (although i think the alt has to be removed to be tested)
-cutts-
Old Sep 13, 2008 | 09:09 AM
Cuda_jim's Avatar
Cuda_jim
How old are they?
Have you put a 1-2 amp charger on the batteries over night?
Checked the water and connections?
You can check the alternator with a volt meter. Get it running, turn on everything electrical, @ idle you should have 13 volts or higher measured across the battery terminals check both of them.
After they are fully charged, Have them load tested, the battery cables need to come off for this....
Old Sep 13, 2008 | 09:13 AM
Cuda_jim's Avatar
Cuda_jim
You need to remove both positive battery connections, put an amp meter between the + post and the + battery cable on only 1 of the batteries.
An current draw of anything higher than .05 amps is too much.
Old Sep 13, 2008 | 10:21 AM
scatgo's Avatar
scatgo
Thanks....................
Old Sep 13, 2008 | 11:37 AM
Talyn's Avatar
Talyn
yea, charging you should get 13+ on the voltmeter.
if you kill the battery and dont get a good recharge on it, then you will have the problems your having.
make sure to check the acid on them to make sure you didn't boil the batteries.
If they are really low, make sure you fill them up with acid or distilled water like your supposto. =)
Old Sep 13, 2008 | 12:08 PM
kawa's Avatar
kawa
Sorry Talyn:
Adding acid is a NO NO. Just add distilled water.
Rog
Old Sep 13, 2008 | 01:27 PM
IDMooseMan's Avatar
IDMooseMan
If you or someon you know has access to CostCo, I'd suggest looking at their Kirkland batteries. I bought two a few years ago ($55 each, $110 total, and a $5 rebate for each battery when I recycled my old batteries) and have had no problems with them.
Old Sep 13, 2008 | 01:57 PM
scatgo's Avatar
scatgo
Originally Posted by kawa
Sorry Talyn:
Rog
Cant seem to add anything. Cant get the caps off. Not sure if they are supposed to come off. The battery says maintenance free on it.
Anyone know if these caps come off?
Old Sep 13, 2008 | 02:03 PM
IDMooseMan's Avatar
IDMooseMan
"Maintenance Free" usually means "sealed" as well. I don't think the caps come off.
Old Sep 13, 2008 | 02:04 PM
scatgo's Avatar
scatgo
Originally Posted by Cuda_jim
How old are they?
Put it on the charger at noon but I cant get the blasted caps off to check for water. Don't want to force them. Not sure if the can come off.
Old Sep 13, 2008 | 04:19 PM
scatgo's Avatar
scatgo
Jut removed both cables to test for current draw both were pretty clean but scrubbed them all anyway. Unfortunately the Radio Crap meter I have only reads mA which is milliamp which = .001 of a amp. When I hook up the meter to the + of the batt a + cable it will spike to the max for a second then drop down to 15. Since I suck at math I am guessing this is .015 mA and should be way below .05. Any one know if this is right?
Old Sep 13, 2008 | 04:23 PM
BlueMule's Avatar
BlueMule
Well I can see the problem from here. It's the blue sticker!
The one that says AC Delco. Fords don't like being force fed GM parts.
Old Sep 13, 2008 | 04:25 PM
BlueMule's Avatar
BlueMule
Have you tried popping the caps off with a small screwdriver? You should be able to get the blade under the cap from the side near the vent.
