Sponsored by: Real Truck
Short bed Dually
Old Sep 13, 2008 | 10:16 PM
jpeters1's Avatar
jpeters1
I have seen short bed duallies and they have the gas door on the fiber glass fenders also since the fenders cover it up.
Old Sep 14, 2008 | 09:22 AM
podirtfarmer's Avatar
podirtfarmer
As I have read and researched there is not to much difference detween the 250 and the 350 rear diffs unless spec orders this truck has a nice posi in it now. and as the basics will tell more rubber on the street more traction. The engine has a Bully dog six position computer plus a Injector pressure chip Injectors are also set up for about a 120hp increase 4"down pipe 5" straight pipe exhaust Stage 3 cold air intake and Methaneole injection. The truck has not been Dynoed yet. the estimated HP is based on the math of the up grades. I am looking at building just a different truck that should run in the 11's at the strip. Cause there is nothing more fun than smoking car with a old diesel truck
Old Sep 14, 2008 | 01:25 PM
Monsta's Avatar
Monsta
Sit. Stay.
There's quite a difference between the axle of an F-250 SRW and an F-350 DRW.
The SRW uses a Sterling.
The DRW uses a Dana 80. It is a much stronger axle by comparison.
Old Sep 14, 2008 | 06:55 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
Don't forget stickers add 50 hp each...
Old Sep 14, 2008 | 07:38 PM
podirtfarmer
No stickers on this ride no need to advertise also the comparison is between srw trucks
Old Sep 14, 2008 | 07:54 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Thers IS a difference though. The 250 has a 35 spline shaft and the 350 has a 37, its just a touch bigger too. Figured I'd post up the numbers, it's enough to rate the truck differently I suppose. Read: https://www.ford-trucks.com/forums/5...-and-f350.html
And here's even more about the differences between a 250 and 350. Just copied this guys post over.
Old Sep 14, 2008 | 08:36 PM
texastech_diesel
Token Redneck
Wait your profile says 1999. Totally different book than the new SDs. I was in the mindset that you were running a newer PSD.
If it's a 1999.5 and up its a Sterling 10.5", no difference between the 250 and 350. Not sure when they changed stuff?
What engine are you running? 7.3 DI?
Old Sep 15, 2008 | 06:01 AM
podirtfarmer
Yes no cats no muffler
Old Sep 15, 2008 | 07:02 PM
King of the Road 04's Avatar
King of the Road 04
Originally Posted by Monsta
Sorry...that's isn't correct either.
You have no traction in the snow because snow doesn't offer the friction coefficient of asphalt! If if had the same friction then a dually would have the same traction. Dually's have higher flotation in snow and rain but that can be offset (to a degree) by having weight over the wheels.
The larger the tire's contact patch, the larger the area of friction, hence the more available area for traction. Tread design, the friction coefficient of the road surface, weight displaced all have bearing on available traction.
Obviously snow doesn't have the same friction coefficient as asphalt, believe me Ive found out on more than one occasion.
Not to bust anyones gonads, but isn't higher flotation directly related to the size of the tire/tires contact patch area? I mean, why would Tanks need larger and larger tracks in order to offset their increased weights, why would off road trucks (HEMITTS and the like) have extra large wide tires?
Tire design is of the utmost importance, but so is tire sizing depending on the situation at hand.
And again, I know I'm comparing apples and oranges, but look at the the difference in tire size on a WRC Rally Car, let alone tire design, depending on the conditions of the track.
Old Sep 15, 2008 | 07:52 PM
Monsta's Avatar
Monsta
Sit. Stay.
No gonads have been hurt in the making of this thread.
My posts were only posted to correct this statement and the other previously quoted.
Originally Posted by King of the Road 04
More rubber does not equal more traction in snow since the weight is spread out over more rubber/the contact patch.
Codyaye
Nov 16, 2024 09:24 PM
juchertf100
Jun 11, 2017 02:11 PM
DasHaas
15
Apr 26, 2012 10:08 PM
Redone
Oct 28, 2003 11:35 AM
Buckshot
Jun 17, 2000 08:04 PM
