Sponsored by: Real Truck
Death wobble ?
Old Sep 12, 2008 | 05:53 PM
bohiaa's Avatar
bohiaa
Death wobble ?
hay all:
was reading about death wobble and not sure if that's what I got going on?
around 32 - 34 MPH my 2000 F 250 starts to bounce a bit in the front end,
the tires look good, had then re ballanced, one tire shop the guy said it looks like a tire is outta round, But I didn't see it.
it only does it at this rather low speed, any other speed it's just fine.
I guess my Questions is, if a tire was outta round would this only happen at this speed? and could it be a simple as the tires?
Thaks
Old Sep 12, 2008 | 08:12 PM
XLnAK's Avatar
XLnAK
It could be the tire. I spent years trying to get rid of such a out of round or unbalanced feel on my 83 1t. Turned out to be a mis-punched lug bolt pattern in a stock steel wheel. Mounted on a balancer the darn thing ran true as gold, but mounted via wheel studs the thing jumped enough that you could see it plain as day. A tech spotted it with rear off the ground rotating the wheel and brought it to my attention. Ran that rim for some ten or so years before finding it. Yikes. Also a word on balancing. I had a reputable shop (S_ _rs) balance a set of new tires once and had to have it redone three times before they admitted there weights would not stay on my rims, and gave my money for the service back. I documented all weights on all sides of the rimes after the first balance to check at a later date. But with in the first "few" miles I could feel things just not right. So I referenced my notes and found several weights( more than five) had ejected from the scene. They try-ed two more times and gave up. Another shop had the proper weights and they stayed well. Death wobble seems to be a much different animal. I dont have any first hand knowledge of it though, other than reading its threads here. Best wishes.
bergysport
1983 - 2012 Ranger & B-Series
May 13, 2014 12:54 PM
7278ford
1978 - 1996 Big Bronco
24
Feb 4, 2013 05:17 AM
mblanken881
Feb 13, 2011 10:14 AM
John with beastly 302
Sep 16, 2010 03:14 PM
bonechief
Offroad & 4x4
Sep 28, 2006 06:12 PM
