Anyone have any experience replacing worn out body mounts on a superduty? An experienced mechanic told me mine are shot. I can't find any on the internet parts sites. Did find a site that said there are 6 of them. This is is on a 1999 F250 Superduty 4x4 diesel with 150,000 miles. No modifications. Lots of rough dirt road driving. Sure would appreciate some advice from all you experts. Still runs great. Just have a lot of clunking noise. I would like to change these out myself. Thanks folks!
Can't help you but i am subscribing. My cab has a slight lean to the left and i am sure its the body mounts. Also check in at the superduty forum. Maybe do a search.
Bumpers the same height from the ground on each side? If yes, then it's probably body mounts. If not then it's something else. Went through this last year.
I think I may have a slight problem with this as well. The passenger's side of my front bumper is about 3/4" lower than the driver's side. The bumper could be slightly off, but I'm not sure. I have had it off one time doing some work to the front end. If you could post some pics of your worn out body mounts so I can compare would be great.
