Offroad & 4x4
question about transfercase leak
Old Oct 29, 2002 | 04:07 PM
dcarling's Avatar
dcarling
[updated:LAST EDITED ON 29-Oct-02 AT 05:09 PM (EST)]I have a 1990 F-150 4X4. The BW 13-56 transfercase leaks. It's not coming out around the shafts but were the rear shaft extension yolk connects to the main case. The question is if i take the shaft and the bolts out of the extension yolk, will it come off or can it only be removed with a complete overhaul?
Old Oct 29, 2002 | 08:08 PM
wille3r's Avatar
wille3r
Old Oct 30, 2002 | 03:40 PM
Maxduty's Avatar
Maxduty
It should come out, if your truck uses a slip shaft. If not, take off the yoke and try from there.
Old Oct 30, 2002 | 04:00 PM
dcarling's Avatar
dcarling
[updated:LAST EDITED ON 30-Oct-02 AT 05:02 PM (EST)]Yes It has a slip shaft and If I disconnect the driveshaft at the rear end it will slip right out of the transfercase. There is 4 "stared" bolts holding the extension yolk on. If I take these out it will come off???? I want to put a new gasket and put it right back on.
Old Oct 30, 2002 | 09:43 PM
Ford_Six's Avatar
Ford_Six
It should come off without any "convincing", just a light prying. Drain the fluid first, and be sure to have a pan under the housing when you pull it off, to catch any runaway parts.
Jared
Old Nov 3, 2002 | 01:57 PM
motobub's Avatar
motobub
Don't be suprised if oil runs out when you pull the shaft out. I changed my u-joint and some came out, I later learnerd that this is normal.
Lars
