rebuild injectors
Old Sep 9, 2008 | 10:50 PM
walkerplay's Avatar
walkerplay
rebuild injectors
how often do rebuild injector go bad . just put one in.took the vc started it up without the vc on then pull the wire on that injector no change in the motor.
Old Sep 9, 2008 | 11:06 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
How long ago did you "just put one in". You have to run it for a good 100 miles or 10 mins at 3000rpm to move all the air out of the injection system... Ya sure you removed the connector with two wires, or the single wire connector?
Old Sep 9, 2008 | 11:17 PM
walkerplay's Avatar
walkerplay
just replace this week, i drove it about 200 miles. still was skipping. yes it was the two wires not the the white one.
Old Sep 10, 2008 | 06:20 AM
F350-6's Avatar
F350-6
Swap that injector with the one next to it to see if the problem follows the injector or stays in the same hole.
There have been issues reported with reman injectors not working properly.
Old Sep 10, 2008 | 08:57 PM
walkerplay's Avatar
walkerplay
thanks i will try that
