Hydroboost?????
Old Sep 9, 2008 | 10:32 PM
a711112a's Avatar
a711112a
Hydroboost?????
got a power steering question
i have a power steering fluid leak on the pressure line going in to the steering box.... during my parts search i found lines for a Hydroboost.. what is it ???? and how do i know if i have it ????
Old Sep 9, 2008 | 11:15 PM
ford trans tech's Avatar
ford trans tech
hydra boost is a hydraulic power brake system if yours has it the power steering lines also attach to it , it is operated by the power steering pump
if your truck has the usual vacuum brake booster then it doesnt have hydra boost
Old Sep 9, 2008 | 11:32 PM
Dodge/Cummins's Avatar
Dodge/Cummins
I want hydra-boost.
I'd never heard of it until I saw Dave S. and somebody talking about it.
I need to look up the old thread and learn more.
Old Sep 10, 2008 | 06:48 PM
a711112a's Avatar
a711112a
thanks ford trans tech
mine does not have it.
Old Sep 10, 2008 | 10:27 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Hydraboost means you can stop, even when you are grossing over 17,000 pounds on the truck.
I have better brakes with 3 tons of stone on my dump than I had with stock brakes and an empty truck.
The only down side, if you use new parts, you are looking at close to 750 dollars in parts.
Also if you brake lines are not in good shape, they will need replaced as well.
Old Sep 11, 2008 | 06:55 AM
Dodge/Cummins
I think it'd be worth it. When I can afford it I'll be buggin' ya' about it.
I'll check out the old threds but I'm sure I'll have questions.
I'll probably have to find another Ford dealer to get the parts from as the local one doesn't give much of a discount to my Dad's machine shop and the parts man and him are buddies. I'm sure the price is dictated by the "management". The Dodge and Ford dealers on town are part of the same "company", neither are known for their great prices.
Joel Cassell
Apr 7, 2015 02:52 PM
89danford
Feb 17, 2014 04:35 PM
okie72
Feb 15, 2014 09:35 PM
.Artisan.
Jun 25, 2011 02:31 PM
78_f800crewcab4x4
Offroad & 4x4
13
Feb 23, 2008 02:27 AM
