Silver Seal for Heads??
You put this in your radiator and it some how replaces missing gasket material. I will be replacing my head gaskets in the near future.
I have to replace my furnace first as winter is comming and I have one on order, should be at the terminal tomorrow. Any help would be great on if additives work. I am only looking for a 3-6 week fix. Hopefully 3 paychecks.
Sorry, I have an 84 6.9L stock 166,000 miles. Thanks for the help, Stephen
It might slow down or stop the leak, but it also might stop up the heater core, oil cooler and radiator.
I am not a big fan of stop leak or other products like that.
Heater core, about 40 dollars
Oil cooler bundle, close to 1000 dollars.
Radiator, around 400 dollars.
If it were mine, I can by a lot of distilled water for 1400 dollars, it can leak for 6 weeks if it has to.
As was already said.
Different leak but....about 13 years ago I had a Dodge that had a pin hole in the radiator tank and I used some of that 2-part epoxy repair stuff, I used it as the directions said. My buddy owns that truck now and it is still holding strong. No good for your problem but works great on radiator tanks.
I have used Bars Leak in an emergency where there was no other option and had no problems later on. I tend to keep my vehicles a loooooong, loooooooooong time so I would know of a blockage problem.
I hadn't thought about the other systems it would effect. I have replaced my heater core and radiator within the last 5,000 miles. I was afraid I would blow out a gasket piece while driving down the road. I will take Dave's advice and carry several gallons of distilled water with me. Again, thanks for all the help. Stephen
I wouldn't do that to anything I own now.
Those other vehicles I had were so problematic you wouldn't have been able to blame anything for had caused the next problem down the line.
