Pushbutton 4x4 vs manual 4x4
i am going to get the hubs changed over to manual soon. as for pushbutton 4x4 i would never own one. i like my lever to much. and the fact that i dont need a crazy procedure just to get the thing in 4 wheel drive. thats just my 3 cents
>"shift-on-the-fly" regardless of whether you have a manual
>floor mounted shift lever or a rotary **** on the dash. The
>F-150 hubs are automatically engaged in either form, there
>are no manual hubs. The F-250/350 hubs have "auto" and
>"lock" on the hubs, but are not true manuals as they don't
>have a "free" position. This means you can shift into 4HI
>in a 3/4 or 1 ton truck without ever getting out of the
>vehicle. It doesn't mean it will engage
>-Kerry
Unless something's changed recently, on the Super Duty's, if you got the lever, you got "real" manual hubs. The electronic shift got the hubs with "auto" and "lock", which are still better than regular auto hubs.
1995 F-150 Supercab XLT 155" 4x4 M5OD 302
1986 F-150 4x4 NP435 300
>98% of them that I would want are pushbutton 4x4<
In my post I was restating a generalization that seems to be true for my area as well. The auto/lock esof in the 3/4 & 1 ton trucks are pretty much the standard (although they are an option) unless you order the manual from the factory (or get lucky(?) and find a stripped down fleet truck). Trying to find a lever shifted xfer case in any truck with the newer body style is a pain. I know, I spent several months looking for one (that's the '00 listed below) w/ a manually shifted s-o-f. That way I would still have a small bit of comfort knowing something was going into gear, even if the hubs don't lock.
I'm happy with my truck, just wish Ford would quit trying to make each year a bit more complicated than the last.
-Kerry
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds
.Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Then I bought a '95 F-150 with manual hubs. Ford referred to them as 'severe duty manual hubs' in the owner's manual. They too, gave me problems during the winter. When I locked the hubs in at the wheels, occasionally they would grind and not fully lock into place..which would cause the front tires to not pull.
Right now, I've got a '99 Ranger with the off-road package. The 4-wheel-drive system on it is all electronic, and so far it hasn't given me any problems. I can hear the transfer case engage, just like with the other trucks. It's a strong system. I love the ease and convenience so far too. I don't have to get out in the mud anymore...or get out in the cold and snow just to keep driving anymore.
Personally, I think NEITHER system is more dependable than the other. The only advantage of manual hubs is that in 2-wheel drive the front end is completely disengaged, which will slighty increase gas mileage and decrease wear and tear on parts.
Someone above said something about ford's manual locking hubs that they weren't reliable or something. On my '83, the hubs are the same exact style as regular Warn hubs, and they have never failed me, other than when it was my error in re-assembly. When I wheel, I wheel hard, probably harder than I should, and I would never own a truck with push-button 4wd or automatic hubs.
On push-button 4wds, you run the risk of ANY of the electrical components failing you at any time, on the manual style they do not exist, how can they fail? Logic dictates that this IS a better set-up. Just my $.02.
Lever
Pros:
you can feel the 4X4 process
there is another lever to grab
you have a Neutral Position
cons:
you can grind gears if you switch from Neutral
most of the time, you get manual hubs, too and thats one more thing to do before hitting the trail
Dial, or button:
pros
Dont have to open your door to engage the front axle
you can still hear, and feel the tcase engaging
safety thresholds wont allow you to damage your system
there is no guess work weather or not you're in gear
cons
lacking a lever
no neutral position
you can only hear (not feel) the gears engaging
its a matter of preference. I've pushed both systems to the same whoopin every time I hit the trail. both systems are fun...
good luck!
Tony
This is the satement that got me in trouble up there >
ESOF is a convienence, and is more prone to malfunction than a manual setup.
Have fun guys, got to get back up there and school them on this subjcet!!
