wheel base
Sep 9, 2008 | 07:41 PM
wheel base
what wheel base options came with 1973-1979? what are the lengths?
Sep 9, 2008 | 08:27 PM
From memory (I think):
Shortbox 6' styleside bed - 117" wb
Regular cab 8' bed styleside and 1979 F350 4wd - 133" wb
All 2wd F350 regular cab 8' bed styleside - 140" wb
Not sure of supercab, crew cab, and chassis cab wb lengths
Sep 10, 2008 | 08:49 PM
What is the width and weight on a '78 styleside 6' 6cyl?
Sep 11, 2008 | 06:17 AM
SuperCab short bed 139"
SuperCab Long bed 155"
Crew Cab Short bed 150"
Crew Cab Long bed 166"
I know I am correct on the SC LB, the others are from memory.
Matthew
Sep 11, 2008 | 08:58 PM
well i was looking in the Chilton's manual and they made a 104" wheel base. pretty short must have used them as tugs or somthing. thanks guys
Sep 11, 2008 | 10:54 PM
Bronco has the 104.0 WB
Quote:
Originally Posted by
capnmorgking
Sep 12, 2008 | 07:18 AM
capnmorgking
No Ford truck ever was offered with a 104" wheelbase.
104" is prolly a typo.
Super Camper & Trailer Specials are Regular Cab pickups on a
140" wheelbase.
Sep 14, 2008 | 04:20 PM
Sep 14, 2008 | 06:06 PM
the shortbed is 6 1/2 feet not 6.
Sep 14, 2008 | 06:09 PM
NumberDummy
Super Camper & Trailer Specials are Regular Cab pickups on a 140" wheelbase.
NumberDummy, how come perky has a 1975 F250 Trailer Special Supercab? you just stated they are regular cabs.
Sep 14, 2008 | 06:12 PM
Rebel Warrior
the Bronco was built on the same frame as the F150, and the F150 doesn't have a 104 inch wheel base.
Sep 14, 2008 | 06:42 PM
I dont know who told you that?? Here is the door tag on my 1979 bronco, the focus is off a little, but you can tell it says the WB is 104''
Sep 14, 2008 | 06:55 PM
it clearly says 104 inches, but if NumberDummy says it I can't argue with him. I read the frame thing in a Ford magazine some time back.
*Edit*, measure from the center of the front hub to the center of the rear hub and tell us what you get.
Sep 14, 2008 | 07:11 PM
my bronco is registered as a station wagon, does that count? who said California knew their back side from a hole in the ground, anyway??
Dr. Dirt
Sep 15, 2008 | 10:40 AM
did you measure the wheel base or not?
rsh1966
Mar 17, 2017 07:20 AM
Huskerman
1983 - 2012 Ranger & B-Series
Oct 26, 2016 12:29 AM
bsteele52
Jan 11, 2010 09:42 PM
Snowseeker
Feb 25, 2006 09:26 PM
papawfalcon
1978 - 1996 Big Bronco
Nov 19, 2005 05:04 PM
