Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
46 Mercury progress 1
Old Sep 9, 2008 | 01:45 AM
Snowking's Avatar
Snowking
Yellow and Red, what a combo
Haven't you ever just said, "Why am I fixing this"?
Earliest factory sliding rear window?
Por 15, solid as steel
Well the yellow is gone
roof work came out good
firewall I'm likin the gloss black
New cab corner
Old Sep 9, 2008 | 07:31 AM
96sherm's Avatar
96sherm
i don't think we needed reprints, but at least you can hand them out now...
Old Sep 9, 2008 | 10:20 AM
preppypyro's Avatar
preppypyro
Looks great Ryan, I love the look of a nice fresh painted frame!
Where do you get your por15 from?
Old Sep 9, 2008 | 10:55 AM
Snowking's Avatar
Snowking
Walkers autobody on Faithful.
Old Sep 9, 2008 | 08:57 PM
Corner Gas's Avatar
Corner Gas
Looking good Ryan. I have heard good things about POR15 also.
Old Sep 9, 2008 | 10:02 PM
Dustin1690's Avatar
Dustin1690
Lookin good alright keep up the good work Ryan
Old Sep 9, 2008 | 10:42 PM
preppypyro's Avatar
preppypyro
Ive heard pretty good stuff about por15 too. Heard a few bad things, but way more good then bad.
With results like Ryan got on his frame, I cant wait to try it.
Old Sep 9, 2008 | 11:12 PM
Fomoko1's Avatar
Fomoko1
From what I`ve read POR15 is real tuff stuff but it fades badly in direct sunlight (so it`s fine for vehicle frames). It takes a special and fairly expensive primer coating if a top coat is applied over it. You must immediately clean the brushes or paint guns used to apply it, it will harden rock hard!
I prefer Zero rust, it`s possibly some what cheaper at just over $100 a 3.78 litre can, minimal prep work (much like POR15) and if carefully applied some paints can be used over it without any special priming. It`s kind of funny stuff, Zero Rust never completely hardens underneath so it protects the steel surface very well and seems to stick fairly well too.
Old Sep 9, 2008 | 11:15 PM
preppypyro's Avatar
preppypyro
Is zero rust the stuff from canadian tire? I do believe I have seen it before, just cannot remember where.
Do you know how much por15 is for a 3.78 (why the hell didnt they just make it 4!!) liter can?
For prep work for both, all you have to do is get all the loose stuff off, correct??
Old Sep 9, 2008 | 11:25 PM
effie_man's Avatar
effie_man
por15 runs about $120-150/"4L" and zero rust is around 100 bucks. Im not a big fan of zero rust just for the fact that it doesnt harden. Havent tried por15 but the next project i do im trying it. Ive heard lots of good stuff about it and it turns white in direct sunlight after a number of years. Por15 you can spray or brush right over rust and it penetrates and seals it
Old Sep 9, 2008 | 11:37 PM
Fomoko1's Avatar
Fomoko1
You are correct, get all the loose stuff off you can and it should be good enough.
I`ve been told that the better the surface is cleaned the better Zero Rust will stick around. If I`m really concerned I sandblast first though I`ve found the Zero Rust isn`t all that fussy, seems to stick ok on frames where it`s too hard to really clean it that well.
Old Sep 10, 2008 | 12:02 AM
preppypyro's Avatar
preppypyro
I do like the fact that you can brush that por 15 on, is it the same with zero rust?
For a frame job like Ryan did (or say one under a f250 diesel) would one can be enough?
Im really unknowlegable when it comes to painting stuff, I have alot to learn.
Old Sep 13, 2008 | 09:11 PM
Snowking's Avatar
Snowking
One 50 dollar can I did my frame/ floor board and firewall.
If you're really unknowlagable aka Stupid just go to Walkers and tell them what you want to do, they will tell you te proper steps, product, and usage you'll need to know. They are who taught me what to do, so you might as well go see the teacher not the student.
Old Sep 14, 2008 | 09:59 AM
preppypyro's Avatar
preppypyro
Haha i love the way you put things man.
Old Sep 14, 2008 | 10:39 PM
Dustin1690's Avatar
Dustin1690
No doubt lol!!....
