Trans temp?????
Old Sep 8, 2008 | 10:34 PM
crazymut's Avatar
crazymut
Trans temp?????
I have a PSD, just put my gauges in, My trans temp is around 165 at normal cruising, 75mph. Is this normal, what should I expect?
Old Sep 8, 2008 | 10:58 PM
superduty4x4's Avatar
superduty4x4
Sounds normal to me.
Old Sep 9, 2008 | 12:46 AM
UP_There's Avatar
UP_There
Very normal numbers......definitely in the safe range. What size tires are you running? Bigger ones tend to work the tranny a bit harder, and raise the temps a lil
Old Sep 9, 2008 | 01:06 AM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Yup, its normal. As your power is increased, w/ Dp Tunes or any other chip/programmer, your temps will go up also.
Old Sep 9, 2008 | 09:44 AM
Ponyboychris's Avatar
Ponyboychris
Rule of thumb for tranny temps. 60 - 100 degrees over ambient temps.
Old Sep 9, 2008 | 10:00 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Before I installed the Tru-cool cooler, I was 170 at 70 mph empty. I installed the cooler and I was never above 155 pulling my 32' TT at 65-70 mph. Flat land of course.
Old Sep 9, 2008 | 10:56 AM
white Buffalo's Avatar
white Buffalo
you should ussually see tranny temps about 70 degrees above outside ar temps, with the truck unloaded & not towing. Towing is a different story.......
Around town driving the temps can show a bit higher since the TC is unlocked under 35 mph and generates alot of heat.
Old Sep 9, 2008 | 11:03 AM
big poppa's Avatar
big poppa
Your numbers are the same as mine and from what everybody is saying, were cool,lol.
Old Sep 9, 2008 | 12:02 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
You COULD really benefit from a larger cooler, though. With my 6.0 cooler in 80-90* heat i run about 30-40* cooler. Every 10* cooler the transmission average's temperature is, theres a certain amount of miles its expected to last longer.
Old Sep 9, 2008 | 01:06 PM
superduty4x4
Good point Kris.
Old Sep 9, 2008 | 02:12 PM
John311t's Avatar
John311t
Normally cruising 75mph for me my temps are 125*. I get to 165* sitting in stop and go traffic unloaded, lol. Not too shabby, running 37's also.
Old Sep 9, 2008 | 03:56 PM
Benny2002's Avatar
Benny2002
That is low john, what gauges are you using?
Old Sep 9, 2008 | 04:00 PM
John311t's Avatar
John311t
Autometer Sport Comp2.
Old Sep 9, 2008 | 06:09 PM
crazymut's Avatar
crazymut
Tire size
I am running 265/75/16 BFG's All Terrains. I did not have any gauges untill the same day I put the DP Tuner on so I had no referance as to what was normal temps on my truck.
Old Sep 9, 2008 | 06:10 PM
crazymut's Avatar
crazymut
Thanks everyone for the response to my questions.
