AutoEnginuity's
Old Sep 8, 2008 | 10:25 PM
walkerplay's Avatar
walkerplay
AutoEnginuity's
just asking here? with the 7.3 bundle what other cars dose it work with. just tring to get my money worth. . or what do i need then ......... thanks
Old Sep 8, 2008 | 10:46 PM
dmueller71's Avatar
dmueller71
I may be the first "naysayer" but I've had some issues with the AE tech service. When I first bought the AE with the Ford enhancement, it worked fine. Then all of a sudden after installing an update, I have yet to be able to use it on my SD. I've E-mailed repeatedly and the responses are of no help. Granted, this is not my #1 problem in my world, so I don't call them every day, but you would think that for the price you pay, that they would put a little extra effort into solving a customers problem. I guess that since that's not the way I run my business, that explains why I still work my butt off, and still ain't rich.
Old Sep 8, 2008 | 11:05 PM
preppypyro's Avatar
preppypyro
Dan whats the price for something like that? How does it hook up to your truck, do they provide you with a usb cable that attatches or soemthing?
Old Sep 8, 2008 | 11:07 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Enhanced ford bundle works for any ford vehicle with OBD II
Mine was like $350, and a usb cable end on one end and the OBD connector on the other end.
Old Sep 8, 2008 | 11:22 PM
aldridgec's Avatar
aldridgec
For the proposed functionality it's a bargain. I believe anything you pay for should work as advertised, but in the professional world, the expense is MUCH MUCH greater than what you get with AE. I have had some difficulties getting it to work at times, and it has crashed or locked up at others, but it is a great value. However, the price one pays for the professional versions of scanners means they have to work all the time every time and accurately. I'm not sure I could rely on AE in a full professional environment.
Old Sep 8, 2008 | 11:25 PM
preppypyro's Avatar
preppypyro
Im gonna have to look into it, sounds like something i would like to have around to play with.
Old Sep 9, 2008 | 01:50 AM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
I have a friend who has an AE. That thing is great. One of these days I shall purchase one as well. Hmmm, someday.
Old Sep 9, 2008 | 06:10 AM
PowerstrokeJunkie
Trust me, the scanguage is cooler, and easier to use. The only benefit would be if you were only using the AE to read your truck, and not help out other people.
Old Sep 9, 2008 | 08:59 AM
white Buffalo's Avatar
white Buffalo
Sound like I ran into a similar situation. After installing the 6.1 unpdate it is required to reactivate the enhanced Ford feature (in the help menu on the top toolbar). Unfortunately my previous activation code did not work, but when I contacted AE I with my username and code on the back of the controller they e-mailed me a new activation code the next day.
Here is the e-mail address I used:
activation@autoenginuity.com
For the price AE is worth it in my opinion considering a NGS scanner is easily double the cost. With AE I have been able to Datalog ICP, duty cycle, KOER test, KOER test, pull codes, live data etc. Like Kris stated above you can also do these functions with the Aeroforce scan gauge. But with AE I have been able to help out my Schaeffer Customers by showing them their trouble codes and issues without having to go to the dealer and pay for it.
Old Sep 9, 2008 | 09:10 AM
white Buffalo
Sound like I had a similar problem. After downloading the 6.1 update I needed to reactivate the enhanced Ford functions - in the help menu on the top toolbar. new activation code was needed and I contacted AE with my user name and controller ID. The next day they e-mailed me a new activation code and I was good to go. Here is the e-mail address I used:
AE is a good deal for the $ in my opinion. Considering a NGS scanner is easily double that. I can datalog ICP, Duty Cycle, run Contribution test, KOER test, pull trouble codes, etc. Like Kris stated above, the scan gauge can do all this also.
link to : Scan gauge Technical Information
I like having AE since I can pull codes and help out my Schaeffer Oil customers and save them the time and $ from having to go to the dealer.
axel 56
Apr 30, 2011 08:11 PM
flyinnuts
6.7L Power Stroke Diesel
32
Mar 30, 2011 01:57 PM
80351
Maryland Chapter
18
Jan 7, 2009 08:20 PM
Bowstring
New Member Introductions
Oct 22, 2006 04:02 PM
Varnish
May 23, 2002 09:56 PM
