I need some help. My problem is when I run over 28lbs of boost for more than about 20 seconds my check engine light comes on and it acts like it just shuts the turbo off I can only get it up to 16lbs with the check engine light on after about 10 minutes of easy driving the check engine light goes out and everything is fine again. Here's what the truck is. 2001 7.3 6 speed. uprgraded garrett turbo with the banks big head waste gate a banks intercooler, ts performance chip k&n cold air intake and traight through 6" stacks. What can I do to stop the check engine light from coming on and killing my boost? One more question before I go, Why can't I get any boost before 1700 rpm?
itp overboost annihalator. Your overboosting, the pcm reads too much boost, and defuels to prevent damage to your turbo.. The no boost before 1700 is because the turbo is a nodular bearing system and it takes time to get it to boost. Correct me if im wrong, but i know about the overboosting ur having. Hope this helps
Please explain nodular bearing to me. I thought i knew a little bit about turbos and how they work, it takes heat, pressure and exhaust velocity to spool a turbo to create boost, not usually below 1500-1700rpm, but maybe i am wrong.
I said to correct me if i was wrong... a guy explained teh difference of teh nodular and ball bearing to me. Agreed with you though on heat, pressure and velocity. I'm no turbo expert. The stockers are a nodular bearing though, correct?
Well, fair enough. Haha i'll admit when im wrong. I guess i looked at bushed as a nodular, kinda like a smaller cylinder, correct? Isthat what u mean by bushed? Small bronze cyliners, more or less
