That wasnt with the 434 kit was it? If you dont mind saying what pistons and cam etc is in there I'd appreciate it. Also, that graph is for an actual dyno and not a simulated one right?
actual real dyno, check the video, nthis is no 434, I asume he is using a standard 400 crank ,30cc pistons with aussie heads and a cam in the xe262h range...
I couldnt get the video to play for some reason. Wonder what the comp ratio is with the 30cc pistons and aussie heads.
I've been playing around with the CamQuest Software on the CompCams website. Its a free download and I was just curious how accurate the hp/tq numbers are in relation to a real dyno. How accurate is DesktopDyno in relation to a real dyno?
Hello TMI, when you said he was close did you mean on the cam? The cam he suggested is the one that I just bought to install in my 400 build(xe262h, bought the K-kit) Too late now but since your the expert is that a good cam for a 400 with a set of your 14cc pistons, weiand 8010, edel 1406, Headmann headers?
Still planning on calling you to order the pistons this week just waiting for the machine shop to call back and tell me what size to order.
