Clear Coat Issues
Old Sep 8, 2008 | 12:31 PM
straightsixer's Avatar
straightsixer
Clear Coat Issues
Very new to painting so I won't be offended by anything you say. I layed down a base white coat and followed up with clear. The clear went on like I sprayed it with a dry wall texture gun. I got a few ideas from friends and went back and tried again after sanding off most the clear. This time I bumped the psi at the gun up to 40 from 35psi and went slower with my strokes to put it on thicker. It definitely went on thicker, so much so that it began to run. I will see what I have after doing a bunch of wet sanding.
I am using a PPG brand of clear and the strange part is I can't find anywhere that it says to reduce it, so I'm mixing 4:1 with the 1 part being the hardener. One of my questons is should I be thinning this stuff out with a reducer? Any other suggestions? Fortunatly the fender is off the car and I'm sort of playing around right not but would like to have it done before the weather starts to turn cold up north here.
Old Sep 8, 2008 | 12:42 PM
Action4478's Avatar
Action4478
What 's the name or number of the clear ?...
It should have a legend on the can Or the hardener ,to tell the mixing ratio...
some can be 4:1:1
AK Adventurer
39
Jun 7, 2018 10:59 AM
JimG1098
Paint & Bodywork
18
Feb 16, 2015 10:32 AM
slovride
Mar 17, 2013 10:24 AM
whistle1516
Paint & Bodywork
Aug 22, 2011 09:31 AM
4starcstms
Paint & Bodywork
72
Dec 6, 2006 07:43 AM
