EGR Valve
Old Sep 8, 2008 | 11:34 AM
aeroin's Avatar
aeroin
EGR Valve
Hi everyone!
Glad I found this site. Im the owner of a 97 ford ranger and my dad has a 96 explorer. We both have a 6 cylinder 4.0L engine in them and both have our check engine lights on. We read the codes and they both have EGR problems. I was about to try to replace the valve but the flarenut on the line doesn't want to budge. Ive seen suggestions about trying to unscrew it when the line is hot - might try that or heating it up - but I wondered what size that flarenut is. I'm sure if I got a crows foot or a line wrench the right size it would help. I'm guessing it's metric - around 25mm because the biggest wrench I have - 1 inch doesn't fit on it does anyone know the best tool for he job?
Thanks for any good advise ...
Aeroin
Old Sep 8, 2008 | 12:31 PM
Rockledge's Avatar
Rockledge
99% of all EGR codes are a result of a faulty DPFE sensor, or hose issues. Rarely does the valve itself fail. What codes in particular are you getting?
Old Sep 11, 2008 | 11:47 AM
aeroin's Avatar
aeroin
Check Engine Codes
Hey!
Thanks for trying to help me out - I've read most of the threads about EGR valve trouble and every time you ask, "what were the codes?"... I'm sure everyone like me remembers they have an EGR issue and forgets the codes altogether. Nobody you try to help ever answers you! I figured I'd do something nobody else has and go get you the codes to see what you have to say! I had to go barrow a code reader again to get em - and here they are....
P0401 EGR Flow Insufficient
and
P0171 System Too Lean
So what do I do next?
Thanks again for any assistance.
Aeroin
Old Sep 11, 2008 | 12:50 PM
bobbywillis's Avatar
bobbywillis
go buy a egr gasket and make yourself a plate to plug it, you will get more power as well as better fuel economy. Some body in there infinate wisdon thought adding exhaust into the intake would better the emmissions, yah but at the cost of fuel economy.
Old Sep 11, 2008 | 01:31 PM
Rockledge's Avatar
Rockledge
and
I would start out by addressing the P0401 code, which is usually caused by a failed DPFE sensor. See: Summary of the Ford EGR/DPFE System.
Old Sep 12, 2008 | 09:47 AM
tomw's Avatar
tomw
EGR has been used for at least 35 years. It may hurt or help gas mileage, depending upon a mixture of things. Compression ratio, combustion chamber design, quench areas, and the list goes on. To flatly say that it hurts mileage and reduces power is a possible overstatement.
The engineers that designed these systems had more education and equipment than I'll see in my lifetime. If they don't know what they are doing, then perhaps we should all go buy horses. But then again, there is a slight pollution problem that we always see after parades...
tom
strokin'_tatsch
76
Jun 15, 2018 05:27 AM
Stewart_H
Oct 24, 2017 11:57 AM
Tom
2009 - 2014 F150
65
Jan 11, 2014 01:14 PM
Stewart_H
Feb 1, 2012 11:49 PM
