Offroad & 4x4
Axle Identification
Old Nov 30, 2002 | 06:09 PM
Jeff 88 F350 Diesel's Avatar
Jeff 88 F350 Diesel
Axle Identification
Assuming the tag no longer exists, how can I find all the pertinant info on my rear end? Ratio, size, etc...?
Old Nov 30, 2002 | 08:54 PM
1bad400's Avatar
1bad400
Axle Identification
If its in that 88 F-350:
10.25" with either 3.73s or 4.10s(jack up rearend, make mark on u-joint and axle housing and on tire and on the axle tube;count how many times the driveshaft turns to make the tire turn once)
size is harder because you have to pull the diff cover
Old Nov 30, 2002 | 08:59 PM
Jeff 88 F350 Diesel
Axle Identification
Am I wrong in assuming that the gear ration for front and rear axles is the same. If it is, doesn't my truck have a Dana 60 front? If that's true, isn't the ratio 4.56? Or am I just totally lacking any conception here?
Well, it took me forever, but I found it. Yipee-ki-yay.
[link:www.drivetrain.com/Fordtrkratio_posidata.html|Axle Ratio]
Old Nov 30, 2002 | 10:01 PM
steve83's Avatar
steve83
Axle Identification
You can look at the AXLE code on the bottom line of the VIN sticker in the door jamb (if it's a 4-door, it'll be on the back edge of the driver's door). Post it and someone will decode it for you.
Dana axles can be decoded here:
http://www2.dana.com/Expert/wc.dll?DSD~demenu~DEMENUA~
This may help, too:
http://www.visteon.com/technology/automotive/solidindependent_axle_spec.shtml
Old Dec 6, 2002 | 08:44 PM
mdamico's Avatar
mdamico
Axle Identification
Hi to tell if it is a dana 60 look on the top of the outside of the axles where the u joint is all that steering stuff ( whats the word im looking for its been a long day) there will be a sqaure box with four bolts in it thats a dana 60
Old Dec 6, 2002 | 11:20 PM
steve83's Avatar
steve83
Axle Identification
...is "rear", as in "rear axle". Not anywhere near any steering components.
Old Dec 7, 2002 | 09:22 PM
kspilkinton's Avatar
kspilkinton
Axle Identification
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
