If you look on the door jamb label you'll usually find a 4 alpha-digit code (eg. AAHH) that will tell you which code springs you have. However, you only have 4 choices depending on which engine you have.
ON EDIT: Silly me...I see you have an "S" in your VIN so that means you have a V10. C - code 4300lb. capacity
Reason: Added relevant info
