If you drop the access panel under the steering wheel and look up toward the radio area you will see it attached to a small cross piece. It is very hard to see but it's there. There is also a small bundle of wires with no ends that are for customer use. Some are hot with the ignition and one is even hot with the lights on but its been a long time so I can't remember what the colors where.
Denny
Are these bundles labeled? Do they tell you what fuses are for them or the amperage?
I can't remember if wires are marked but the fuse is labeled for customer use. Wires where just setting there with no ends in the same area as the brake controller wires.
